Compressor surging ?
Postby Wolf_Tm250 » Fri Feb 03, 2006 10:13 pm
Hello Mates,
after 22 months of HARD job, finally my car was ready.
I made it mapped, last Tuesday, by Motec's australian engineer Dave Rowe.
On the dyno, numbers were fantastic, over anyone's expectations.... btw, having done ALL the job by myself, I was already happy when I switched it on for the first time and all sounded ok !!! ;-)
BTW... let me describe my... "problem" ?!?
Especially in longer gears, 4th or 5th gear, I push WOT on the pedal from low rpm ( 2500 rpm ), around 3500 rpm the boost jumps up, the engine has some hesitations and the boost gauge start to vibrate up & down !
Dave Rowe told me to decrease the plugs' gap: I tooke them from 0.70mm to 0.60mm, but the problem is still there...
Could it be compressor surging ?
Could it be that, given that I connected pressure line for the BOV and for the EBC togheter, so when the ebc is starting to control the boost, and releasing some air in the atmo, the boost is able to force the BOV spring and makes it flutter ?
Any idea or advice ?
Thank you !
Wolf_Tm250
Wolf_Tm250
Postby Akane » Fri Feb 03, 2006 10:26 pm
Without telling us ANY of your mods, it's impossible to say.
Postby vvega » Fri Feb 03, 2006 10:29 pm
have you got a compressor map for your turbo ??
thats the eazy way to tell
it would be un usually for it to surge at low rpm and not high but anyhting is posible
start with the compresor map and well go from there :D
v
vvega
Postby Wolf_Tm250 » Fri Feb 03, 2006 10:50 pm
Unfortunately I don't have the comp map, it's an unrestrictored version of the WRC turbo, and I don't really know what kind of turbo is...
So I was asking what the surging is like, to understand if it is...
I even have another idea...
At the same pipe coming from the plenum, with a 4 holes joint, I attached 3 pipes:
- BOV pipe
- pressure line for ext. HKS wg ( set at 1.15 bar )
- pressure line for Blitz EBC ( set at 2.00 bar )
Could it be that the boost's variations in the 4-holes-joint is making the wg to flutter ?
Or could it be due to the too much differenze between waste gate opening pressure ( 1.15 ) and my boost setting ( 2.00 ), so when the max setted boost is reached, the wg valve opens too fastly ( for the poor preload ) and makes the boost to fall to rapidly ?
Thank you very much.
Wolf_Tm250
Wolf_Tm250
Postby vvega » Fri Feb 03, 2006 11:14 pm
if your running a steel ct20b (st205wrc) turbo i doubt you are getting surge
you t juntion could could casing a issue
what bov are you runnning ??
vvega
Postby Wolf_Tm250 » Fri Feb 03, 2006 11:37 pm
vvega wrote:if your running a steel ct20b (st205wrc) turbo i doubt you are getting surge
Hi vvega,
no it's not the ST205wrc turbo, it's an unrestrictored TTE-WRC turbo... it seems to be an hybrid T3...
I'm using Greddy Type R bov with softer spring...
Wolf_Tm250
Wolf_Tm250
Postby vvega » Fri Feb 03, 2006 11:52 pm
Hi vvega,
was it bought in nz
if so i will know the man that built it and could probably get some info on it for you
from my understanding it will be a hybrid ct20b :D
though ill check on that
even then a genuine tte item designed for your car will not be surging
it wouldnt win many races like that now would it :D
id seperate the wastegate and bov lines for a start
they should alway have there own dedicated line to the manifold
surging has a very distingtive sound as its bassically cavataing the turbo
is there a noise assosiated with the issue
do the intake temps rise drematiclly ??
v
vvega
Postby vvega » Fri Feb 03, 2006 11:58 pm
if this was the issue with teh wastegate spring tension you would find that the boost would spike and then it woudl struggle to drop down to the proper tension as it woudl be unable to clamp on the turbine pressure
sure way to check is unplug the boost controller in its intiruty and see what happens
so its all a bit disjointed
you have put forward many good sugestions and im just tring to give thme all consideration before answering with something that explanes what i think rather than just a flat answer :D
v
vvega
Postby Wolf_Tm250 » Sat Feb 04, 2006 12:06 am
vvega wrote:
was it bought in nz
I bought it in Germany, from the Toyota F1 motorsport - ex-TTE, and believe me, it's TOTALLY different from a CT20 !
:wink:
http://img516.imageshack.us/my.php?imag ... g014jz.jpg
Ok !
Yes, an hesitation like misfire, and you hear the WG, through the screamer pipe, that opens and closes many times in a second !
I'll check the logs !
Thank you !
Wolf_Tm250
Wolf_Tm250
Postby vvega » Sat Feb 04, 2006 12:13 am
i want a better pic of that turbo please :D
id liek to see compressor side pics ans wastegate side pics :D
i sure you would have taken a few befor you put it on the car :D
v
vvega
Postby Wolf_Tm250 » Sat Feb 04, 2006 12:16 am
Boost is really bouncing up and down on my Greddy boost gauge, and even the waste gate opens and closes many many times in a second...
at the beginning the FOO FOO FOO sound from the screamer pipe is rapid and short, many times in a second... but gradually the FOO becomes longer ( and decrease the frequency per second ) till it become stable...
how can I explain...
" FOO FOO FOO FOO FOOO FOOO FOOO FOOOOOO FOOOOOO FOOOOOOOO FOOOOOOOOOOOOOOOOOOO-stable boost "
Maybe I'll really to adjust wg spring tension... I'll try...
v
I'm doing my best, and you're doing your best ! Thank you !
Wolf_Tm250
Wolf_Tm250
Postby Wolf_Tm250 » Sat Feb 04, 2006 12:21 am
vvega wrote:i want a better pic of that turbo please :D
v
Yes I had.... before my HD went for strawberries....
:evil:
Wolf_Tm250
Wolf_Tm250
Postby vvega » Sat Feb 04, 2006 12:21 am
just a thought if it is a tte tubo you could well be running it under its effencancy range
from my understanding there desided to run at 2 bar
what ignition system are you running and what static compression are you running
v
vvega
Postby Adydas » Sat Feb 04, 2006 12:53 am
mmm 2 bar, thats a figure worth a beer :P
Adydas
Re: Compressor surging ?
Postby fivebob » Sat Feb 04, 2006 12:57 am
Good to here you finally got it mapped, after all those hassles.
Wolf_Tm250 wrote:Could it be that, given that I connected pressure line for the BOV and for the EBC togheter, so when the ebc is starting to control the boost, and releasing some air in the atmo, the boost is able to force the BOV spring and makes it flutter ?!
Yes it could be that. When the shuttle valve opens you lose pressure on the diaphragm and that means the pressure on the turbo side of the BOV is greater and could force the valve open.
From this distance the turbo looks like it could be a CT34 or possibly a CT44/ST hard to tell without a close up photo.
Postby Wolf_Tm250 » Sun Feb 05, 2006 10:36 pm
vvega, fivebob...
first of all, thank you for your help...
I'll post asap an in-car video of the trouble, so to see, first, what is the problem...
fivebob wrote:Good to here you finally got it mapped, after all those hassles.
Yes ! And thank you for the help you gave me to make it mapped for a good running-in !
I divided the pipes, but the problem is still there...
could it be due to low wg opening pressure ( 1.15 ) versus high ebc setup (2.0 bar) = too much difference ?
I'll try to increase the wg opening pressure to the max, around 1.4 bar...
Bye !
Wolf_Tm250
Wolf_Tm250
Postby fivebob » Sun Feb 05, 2006 10:47 pm
Wolf_Tm250 wrote:Yes ! And thank you for the help you gave me to make it mapped for a good running-in !
No problem, long distance tuning was an interesting exercise, wonder if there's a market for web based real time tuning :wink:
Not sure, I would've thought it wouldn't be an issue with proper control of the duty cycle you should be able to work with any pressure spring, to my way of thinking a lower pressure spring, with a lower duty cycle, but higher frequency may give better control.
Have you tried it without the EBC, just relying on the wastegate? I know it's lower boost that you want to run, but that may eliminate the wastegate as a cause and could point to compressor surge as the cause.
If you are getting surge, then can you make the engine flow any more freely than it already is?
Postby Wolf_Tm250 » Sun Feb 05, 2006 11:20 pm
:lol:
When I used it without the EBC, it seemed to me to be fine... I'll check again...
Intake or exhaust ?
Intake I have 2.5" pipes compressor to ic - ic to butterfly, and 70mm butterfly...
Exhaust I have a full free 3" system with screamer pipe for the wg... even if I was going to put it back in the exhaust... it's impossible to use a street car with the screamer pipe !
BTW, in that case, I must reconsider: 3" + screamer is bigger than only 3" ...
PS: did anyone dyno'd the power loss turning the screamer pipe back in the exhaust ?
PS2: I dynoed 526 FWHP, and 588,2 NM ( yes rr dyno are crazy... ;) ), do you think 3" exhaust could be small ?
TIA !
Wolf_Tm250
Wolf_Tm250
Postby fivebob » Sun Feb 05, 2006 11:43 pm
If it is surge then you need to identify the most restrictive part of the engine.
588nm of torque is huge, even allowing for the FWHP "fudge factor", as torque is the best indictation of flow through the engine I think you may well need to increase the 3" system. But that's just a guess, first we need to determine the cause.
Can your EBC do RPM dependent boost control, restricting the max boost at the lower rpms might be a solution. Sounds like this turbo is making some serious boost down low which is the opposite of most 3S-GTE systems and probably why I've never come across surge before, even with huge turbos.
BTW have you got a dyno plot, or at least some more information about where peak torque occurs, and possibly a boost curve from you logs.
Postby Wolf_Tm250 » Sun Feb 05, 2006 11:56 pm
fivebob wrote:If it is surge then you need to identify the most restrictive part of the engine.
Ok...
Ok.
Unfortunately not my id3...
what about the Motec boost controller ?
The Motec's mapper told me to decrease the gap again and again, but now I'm already at 0.60... will try with 0.55mm ...
I have only a pic taken with my phone of the numbers I told you, because the mapper was still refining the maps... but after that we discovered WI pump was not working, so I have a final dyno plot at home at "only" 1.95 bar:
411.8 AWHP at 6.139 rpm
489.4 FWHP ( only 78.4 hp lost in trasmission ???? )
561.1 Nm at 4957rpm
Will show you the plot this night...
And even the loggings of today's trackday ;)
Thank you, mate.
Wolf_Tm250
Wolf_Tm250
Users browsing this forum: No registered users and 22 guests
