AE111 gearbox
AE111 gearbox
Postby johntramp » Sat Feb 04, 2006 5:26 pm
Hey is there such thin as a non-LSD 5spd gearbox from an AE111 with a blacktop 4age?
If so, how can I tell what is LSD and what is not?
johntramp
Postby AceSniper » Sat Feb 04, 2006 5:58 pm
most are non lsd unless out of a BZ-V
AceSniper
Postby johntramp » Sat Feb 04, 2006 8:20 pm
oh ok, is there any way to know what it is without knowing what car it came from?
johntramp
Postby AceSniper » Sun Feb 05, 2006 2:45 pm
turn the shafts method, look in the axle hole see if u see a pin or right through
AceSniper
Postby johntramp » Sun Feb 05, 2006 3:01 pm
AceSniper wrote:look in the axle hole see if u see a pin or right through
which is which? I can't see right through so I guess that is a pin in the way. It is almost as wide as the whole.
johntramp
Postby AceSniper » Sun Feb 05, 2006 7:38 pm
put a shaft in and turn it around see if the oter side turns the same way or opersit
AceSniper
Users browsing this forum: No registered users and 29 guests
