i have been told the a w55 bellhousing will bolt up to a w57 gearbox and viceversa if this is so what i want to no is will a w50 bellhousing bolt up to a w57
also i was told that a 5m flywheel is diffenet to a 7m will a mteu fywheel fit a 5m?
Silent Knight wrote:You can use any W series bellhousing on any W series gearbox. The bolt patterns are the same.
W series gearboxes have a separate bellhousing.
Different bellhousings are used to connect a W50 gearbox to an R or M series engine.
Different bellhousings are used to connect a W55 gearbox to an R or T series engine.
Alloy W5# gearboxes are interchangeable with each other.
Alloy and steel W5# gearboxes are not interchangeable with each other.
W50 bellhousings do not fit the W55 gearbox and vice versa.
W55 bellhousings do fit the W56, W57 and W58 gearboxes and vice versa.
All W## gearboxes after 1970 had the same output spline as the A## automatic gearboxes.
Users browsing this forum: Google [Bot] and 23 guests
