on behalf of mate re gt starlet
Postby shaggz » Mon Feb 13, 2006 4:34 pm
hey got a matae with a gt starlet has exhaust 2>5inch straight through and also boost tap(running 11pound) pod,bov, what other simple mods bar a front mount do yo reckon he should go after next low budget but good increases, ive run outa ideas for him, haha
drive it till it breaks, then upgrade it
Santa Edit: Steve is the former owner of a man-card
shaggz
Postby MrDori » Mon Feb 13, 2006 5:00 pm
Front mount, better manifold and larger turbo will transform your starlet.
vf10, td04s, small t3s work really well on these cars,.
MrDori
Postby Ako » Mon Feb 13, 2006 5:06 pm
Read your own signature stephen :lol:
Ako
Postby FrEsH » Mon Feb 13, 2006 9:13 pm
mount hte pod off the turbo, down pipe, if he doesnt wanna go front mount he can do teh rx7 top mount conversion like me (pm if he wants more details), he could go bigger fuel pump(mazdaGTX ones work well) and a rrfpr and fuel cut defender and run some more boost...altho anything above 14 on stock turbo really makes no difference as it gets too hot....
As said above though the stock turbo = total crap, ditch it as soon as possible if your after decent power
FrEsH
Postby dotdog » Mon Feb 13, 2006 9:58 pm
Yea, id go down pipe off the turbo, airfilter straight off the turbo and rx7 top mount intercooler, all cheap mods
Daily Ride - 00 Subaru WRX STi RA 12.7@113
Project Car- 89 Toyota Starlet Turbo S 95.1kws
Ex Ride - 85 Toyota Starlet Si with 4efte, 1990 Nissan Pulsar GTiR 150Kw/atw, 97 Toyota Levin BZR
My Profile: http://toyspeed.blakjak.net/profiles/profile.php?id=589
dotdog
Postby Elmendorf » Tue Feb 14, 2006 6:55 am
If he wants to do cheap mods he should look at some of the Japanese auction sites and buy things like FCD, SLD, SAFC cheap. I would also recommend upgrading the acutator on the stock turbo, people think its a waste of time but we were running one on our other starlet prior to stripping it down and that thing was fast. Stock actuators are pretty average. But yeah if he doesnt have a decent dump pipe I would suggest he gets one, gutting the cat does improve performance slightly but nothing compares to a straight piece of pipe :D
Elmendorf
Postby 1598cc » Tue Feb 14, 2006 2:31 pm
if you wanna be ruff as with it and dont care about looks;
weld td04l to stock manifold
get a stock td04l downpipe flange and weld some exhaust piping to it
vr4/evo intercooler, or as said a s4 rx7 intercooler; frontmount preferable
2" exhaust piping hacked up for intercooler piping
rising rate fuel reg
fuel cut defender
retard timing abit at the dizzy
go have a power run on a dyno and wind boost up till air/fuels are about 12:1 no higher and no higher than say 18psi?
1598cc
Postby FrEsH » Tue Feb 14, 2006 2:52 pm
stock manifold will crack almost straight away ahah, i dont advise u do that
FrEsH
Postby 1598cc » Tue Feb 14, 2006 3:13 pm
do they crack quite easily?
1598cc
Postby Punter » Tue Feb 14, 2006 3:16 pm
1598cc wrote:if you wanna be ruff as with it and dont care about looks;
Aren't they cast?
Punter
Postby 1598cc » Tue Feb 14, 2006 3:34 pm
yeh they are but ive welded to cast alot with a shitty fluxcore mig welder and its still holding up after at least 15000k's.
apparentlyits best to heat it up then weld.
1598cc
Postby FrEsH » Tue Feb 14, 2006 4:17 pm
they crack allllll the time, they're absolute pieces of s*$t
FrEsH
Postby Punter » Tue Feb 14, 2006 4:46 pm
1598cc wrote:yeh they are but ive welded to cast alot with a shitty fluxcore mig welder and its still holding up after at least 15000k's.
Yea it was just a comment my brother made about welding cast stuff
(hes a proper engineer)
Punter
Postby dotdog » Wed Feb 15, 2006 8:37 pm
Id argee with harlet, get a bigger accuator, i had a t25 one modifyed and insted of dropping boost off up high it picked up boost on the durty old ct9b
dotdog
