How hard to get these bumpers of? (PICS INCLUDED)
Postby DR ROTOR » Tue Feb 14, 2006 2:30 pm
i have the same bumpers as these below im wanting to take mine out....just wondering where the bolts are etc? i dont want to take all my lights and grill out as it will un align everything! but yeah whats te easiest way?? ive taken out like 8 bolts still no luck, bumper leans down but does not come off.. How easy exact bolts to take out? the guy on the auction said two bolts only holding the bumper on.. any ideas will be great
DR ROTOR
Postby fangsport » Tue Feb 14, 2006 3:41 pm
front bumper has four bolts going into top of chassis rail
rear has four bolts going into end of chassis rail
piece of piss, 10 minute job
fangsport
Postby DR ROTOR » Tue Feb 14, 2006 8:11 pm
will try again tommorw! took outheapz of bumpers didnt know why it was so hard on my ke70! thanks for the help! so dont need to take the lights out? what about the endcaps? are they bolted to the bumper?
DR ROTOR
Postby DR ROTOR » Tue Feb 14, 2006 8:17 pm
do you mean these sort of bolts? 4 of them on the front?
DR ROTOR
Postby fangsport » Tue Feb 14, 2006 8:20 pm
no, the 4 bolts on each bumper that holds the brackets to the chassis rails.
fangsport
Postby l1ttle_d3vil » Thu Feb 16, 2006 3:24 pm
what are they off? looks like a ke70?
the ones on my ke35 just had 2 bolts on each side as fangsport has described. just unbolt them and the bumper will be loose and hang down like you said, but you may need a bit of pulling to actually get it out. the ones on my ke35 get wedged in pretty good, just make sure you've disconnected your indicator plugs before you pull it out though! :roll:
