3sfe vs 5sfe?
3sfe vs 5sfe?
Postby Infinite » Thu Feb 16, 2006 5:16 pm
Ok people a quick question 5sfe or 3sfe? what would u prefer?
Lots
Infinite
Postby RomanV » Thu Feb 16, 2006 5:20 pm
I would prefer to throw them both in the ocean. :P
5SFE out of the two, but a 3sg(t)e is a much better choice. 8)
Postby KinLoud » Thu Feb 16, 2006 6:20 pm
5sfe gets my vote - loads (in a relative sense) of torque down low, good for pushing our camry wagon around town and on longer drives... runs out of breath above about 5300rpm.
If this is a choice for your curren - sort out a 3sge. Same effort to put it in, but much more rewarding!
Ken
Ham
021 408 863
Postby Infinite » Thu Feb 16, 2006 6:22 pm
ok so hows about this
a 5S-FE block with a 3S-GE head? then turbo'd? (gte head wont fit the block? aparently a ge will)
Possible? or not? would this require alot of work or?
Lots
Infinite
Postby vvega » Thu Feb 16, 2006 6:47 pm
lol there basically the same head
so i dunno why one would and the other wouldnt
v
vvega
Postby Infinite » Thu Feb 16, 2006 7:09 pm
vvega wrote:lol there basically the same head
v
That is true but when u have everyone giving there opinion alot of people say differnt things :) so u go with what is said the most.
Lots
Infinite
Postby fivebob » Thu Feb 16, 2006 7:13 pm
Infinite wrote:a 5S-FE block with a 3S-GE head? then turbo'd? (gte head wont fit the block? aparently a ge will)
Another internet rumour and AFAIK totally incorrect.
Of course the GTE head will fit, go and have a look on mr2oc.com they've got a thread the details all you need to do to fit a G(T)E head on a 5S-FE block
Postby vvega » Thu Feb 16, 2006 7:19 pm
and that is why the internet is such a bad place to be trin to lern new info
its not so bad if you have soeme backround and can tell the bulshit form the lies :D
v
vvega
Postby Infinite » Thu Feb 16, 2006 7:23 pm
thats why i come here and ask u experts on these forums :)
Lots
Infinite
Postby Malcolm » Fri Feb 17, 2006 12:04 am
problem with the 5s-fe block with a 3sgte head is that some have reportedly the 5s rods/bolts can't handle the revs of a 3sgte (5s redline = 6,000rpm, 3sgte redline = 7,200). Also the valve cut outs in the 5s-fe pistons might not match the 3sgte valves and you may end up with an interference engine.
Basically unless you're planning on a big power engine build, including a fully built bottom end, worked head, big turbo, cams, ecu etc, then there probably isn't much point in going to the 5s-fe block.
Postby vvega » Fri Feb 17, 2006 5:55 pm
the only rod ive ever seen out of a 5s was quite large
i dont tend to belive people unless they have done it themselves
thats the first rule of information off the internet
:D
v
vvega
Postby Malcolm » Fri Feb 17, 2006 6:05 pm
well then I don't believe you :P
to be honest I don't see why the rod bolts would be any lower quality than the 3sgte either, but I would certainly think you'd want to get some different pistons, or just grind the 5s ones down with an angle grinder to suit the valves :D
Postby vvega » Sat Feb 18, 2006 12:56 am
lol no i have attually seen a rod not just been told about it or herd something :D
and there is nothign wrong with a interfeance engine you just have to remeber to do ya cam belt
i have a flycutter attachment for my die grinder for modding relifs anyways :D
geeezzz dont you have any cool tools :D
v
vvega
Postby Infinite » Sat Feb 18, 2006 11:02 am
how about i grind your guys piston's with a 5inch angel grinder?
Lots
Infinite
Postby Toyboy » Mon Feb 20, 2006 7:50 pm
I'm doing a 5sfe expecting between 400 - 600 hp, supercharged + NOS fully worked. :twisted:
"The faster you go, The quicker you get there."
Toyboy
Postby Infinite » Mon Feb 20, 2006 8:29 pm
Toyboy wrote:I'm doing a 5sfe expecting between 400 - 600 hp, supercharged + NOS fully worked. :twisted:
nice my msn is infinite@rianz.co.nz wld be cool to catch up
Lots
Infinite
