aw11 4agze cambelt idler pulley bolt
Postby Psycho_Dad » Sun Feb 19, 2006 9:53 pm
i have been attempting to replace the head gasket on my 4agze(on my aw11) for the last few days. i have a question
ok the nut on the idler pulley of the cambelt, that has the timing pin for the crank pulley on it... i cant undo the nut because it isnt a normal nut.... its sum 10 pin thing cog looking thing, i have to go pick up a tool for it? whats it called?
i buggered the nut trying to remove it with grips, im worried now that i cant replace the nut with a normal 11mm nut or somthing because the pin may be welded to it? is this the case? or if i remove the nut will the pin will be seperate--- hoping so!
also the head bolts, they also are the 10 cog head thing, is this oem?
i know retarded questions, hope someone understands and replies
Psycho_Dad
Psycho_Dad
Postby vvega » Sun Feb 19, 2006 10:02 pm
the head bolts need a special tool ..its like a torx bit but its not :D
and the tensioner is just a double star socket
vvega
Postby Psycho_Dad » Sun Feb 19, 2006 10:07 pm
and where pretel can i find this bit?
as for the idler? is that pin and the "double star socket" made as a single piece or can i just remove the nut(somehow) and replace it with somthing more user friendly whilst still having the pin(since i am a hic, trailer trash backyard mechanic)?
thanks heaps! wanna have this head off by tomorrow
Psycho_Dad
Psycho_Dad
Postby Mr Revhead » Sun Feb 19, 2006 10:54 pm
i just used a ring spanner on the tensioner bolt.. that pin is part of it.
just give me the aw11 and dont let it worry you any more 8)
Postby Psycho_Dad » Mon Feb 20, 2006 10:07 pm
too late, bolts off, next thing send her to get inspected and stuff, hope i can remember how to put her together
peace
Psycho_Dad
Psycho_Dad
