Best Diff set up for a KE36
Postby DIRTYDX » Tue Feb 21, 2006 4:24 pm
Hey everyone im after all the info i can get on what is the best diff to run in my 3tgte KE36,iv heard about hiace,townace,hilux,b1600 setups bein used,but want to hear from others about how easy it is done,what model hiace/townaces have the same width diff as the standard ke36 one etc.Im getting sick of changing these tiny lil 6.3" diff heads so any help will be greatly appreciated :D
DIRTYDX
Postby KE20 » Tue Feb 21, 2006 9:42 pm
the early hilux(1985-89, 5 stud) diffs are 1420mm wide. i have a surf (6 stud) for sale, its 1470mm wide. measure your one to see how wide. then you just cut mounts off original diff and weld on the new diff. mod driveshaft, normaly will need shortning slightly and new end for diff, and sweet as.
Garage Dori
KE20
Postby Jebus » Tue Feb 21, 2006 9:51 pm
Then add, rear brakes. If you go disks, a calliper mount, rotors, calippers, brake lines, handbrake cables. If you go drums, the bolt pattern rotated around 2cm to clear the chassis rail, shortened handbrake cables and a bracket to hold them. A new pair of U bolts, modif the shock mounts.
Not only that but your wheels will stick out about 20mm at least, KE3X width is just under 1390. And youve got 2 or 4 studs too many.
Not just cut/weld and bolt in.
Jebus
Postby fangsport » Tue Feb 21, 2006 11:27 pm
what about 4-stud Liteace van diff?? never measured one, but should be strong enough and relatively easy to convert to disc.
fangsport
Postby Drifter4ag » Wed Feb 22, 2006 8:50 am
e series diff is slightly larger than t series diff ... changing to 4stud is easy .. reading klingon is hard
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
JZX91 MARK II CHASER
Drifter4ag
Postby l1ttle_d3vil » Wed Feb 22, 2006 11:22 am
an ae86 diff will fit in without needing to be shortened. you will just have limited choice of mags though. I can't remember exactly how much wider they are than standard ke36 diffs now though.
how soon are you wanting a diff? I may have a hilux diff, ready to mount up to a ke30/5/6. I don't think it is shortened though; and it won't be for another couple of months that I know whether I keep it and sell it with my 35 or separately.
Postby Jebus » Wed Feb 22, 2006 9:11 pm
Lite-ace diff is about 1410mm, it still sticks out further than stock, which is pretty half arse IMO. And LSD heads are not made factory for them, and youre not cool if you dont have an LSD these days. There are other options, but none that are the right width and require very little or no modification. If there was, think about the amount of people trying do a 'Diff Upgrade' on the cheap, someone would have come across it by now and everyone would be doing it.
Myself ive spent HOURS walking around wreckers and PAP with my tape measure, and best option I came up with to do it properly was modified hilux.
If ya do find something that is the right width, good on ya but someone creating a new thread every week about it isnt going to help that happen any faster.
Jebus
Postby KE20 » Wed Feb 22, 2006 10:41 pm
one way to get around the wider diff is to run fwd offset wheels with spacer/adaptors on the front. or one option is, put mr2 aw11 front struts in, i did that in my ke20. and had a corona 'f' series diff. and had fwd wheels alround and under guards
Garage Dori
KE20
Users browsing this forum: Bing [Bot] and 14 guests
