Yeah, the factory RB20DET intercooler is awful, with a 1.9psi pressure drop. I'm making 12psi at the manifold with a boost controller, which theoretically means that the turbo is producing 14psi, which is at the limit of its' efficiency. This is why guys running 1 bar constantly shit turbos, they may see 14.5psi on the gauge, but the turbo is making almost 17psi..
On that note, if I was running factory 10psi, and installed an aftermarket intercooler with a 0.2psi pressure drop, I would see 12psi at the gauge, although this would affect throttle response (which shouldn't be confused with throttle lag!) but with a cooler charge, would add reliability, and look cool!
All_Fours wrote:does CFM vary with revs and load, or just revs, anyone?
The way I understand it, is both. Revs, and load, hence why when you drive up a steep hill, or are full throttle in high gears, the extra load created adds to the engine load, which in turn works the turbo harder, and creates more boost.
Mmm boost wrote:I thought the obvious explanation was lag is between gears, threshhold is how long it takes to come on boost
Yeah, thats what I thought, except I've heard it referred to as throttle lag, and throttle response.
Moreso, if you had larger intercooler piping, and a large intercooler, the speed of the air is going to be lower, with higher volume (ie, less throttle response, more lag), whereas with smaller diameter piping and a smaller intercooler, it would respond faster, but would lack the volume, so less top end power. Does that make sense? Thats' the way I see it anyway.
