Power steering/air con belts...
Postby trueno_20v » Wed Feb 22, 2006 10:23 pm
Im wanting to take my air con pump out of my car, but the belt off the crank pully goes around the power steering pump too, so does anyone know what size belt i will be needing just to run the power steering with the air con gone? cheers
ADMIN EDIT: signature too large
trueno_20v
Postby 20v_rollaboy » Wed Feb 22, 2006 11:31 pm
And what are you going to use as a tensioner??
Ive tried this and its not possible unless you get a setup from a earlier corolla (not sure which one), but IMHO, too much hassle. Mine just spins on the pulley without actually turning the aircon unit.
20v_rollaboy
