20 valve dizzy vs gze cas?
Postby 4agtepwr » Wed Feb 22, 2006 11:57 pm
Just a quick question
internally are they the same?
4agtepwr
Postby Adydas » Thu Feb 23, 2006 12:07 am
you might want to be a little bit more presice on your question, is What the same the total diameter? the inside part thats stepped back, the mesurement between Point and and point b?
Adydas
Postby RedMist » Thu Feb 23, 2006 8:04 am
I think he's talking more triggers.
In which case, yes they are.
However you can't just plug a 20 valve dizzy up to a 16 valve head.... the drive is different for starts.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby 4agtepwr » Thu Feb 23, 2006 12:41 pm
Thanks Dan. I had a look at the drives last nite i can modify them without to much trouble just make a new shaft at work and make it fit. Was just keen to know if there internally the same.
Has anyone else done this?
4agtepwr
Postby Lloyd » Thu Feb 23, 2006 12:45 pm
The teeth and triggers and things are all the same. I'm using a GZE everything with a silvertop head bolted on and a turbo. Cut the wire to the CAS and work out which one goes to which on the distributor and away it goes. From memory 2 colours were the same and the other 2 swapped but I cant remember the colours sorry :P
Postby 4agtepwr » Thu Feb 23, 2006 7:53 pm
So ive had a look and i can machine up a new shaft and make it fit ok is there anything else that would need changing, This is the triggers for a Link Plus not for a standerd ecu
4agtepwr
