can i put a gen 1 mr2 motor into a gen 2 mr2 car
Postby mr2--mad » Thu Feb 23, 2006 9:00 pm
does "any one" see any problems with this? has any one done this before
mr2--mad
Postby no_8wire » Thu Feb 23, 2006 9:03 pm
So is the engine out of a 1st generation SW20?
The car you want to put it in to is a 2nd generation SW20?
no_8wire
Postby IH8TEC » Thu Feb 23, 2006 9:06 pm
no_8wire wrote:So is the engine out of a 1st generation SW20?
thats pretty self explanetry in his title :roll:
Postby Adydas » Thu Feb 23, 2006 9:20 pm
I dont know, my understanding was he wanted to put a AW11 motor into a SW20..
So i think its a perfectly valid question.
Adydas
Postby Adamal » Thu Feb 23, 2006 9:20 pm
Same engine.
Postby Al » Thu Feb 23, 2006 9:27 pm
One of the main difference will be the speedo drive, does your gen2 n/a have an electronic or cable speedo ? The gen1 turbo gearboxes are cable speedos.
Al
thank you
Postby mr2--mad » Thu Feb 23, 2006 9:28 pm
same engine, sweet im driving to wellington and back tommorow to get the sw20 motor then. i hope your right
mr2--mad
Postby mr2--mad » Thu Feb 23, 2006 9:32 pm
my car 2 is a turbo same as the engine
mr2--mad
Postby Adamal » Thu Feb 23, 2006 9:35 pm
The Gen 1 SW20's came with the Gen 2 3SGTE's. The Gen 2 SW20's came with the Gen 2 3SGTE's.
Postby mr2--mad » Thu Feb 23, 2006 9:36 pm
to al my mr2 car is sw20turbo, i will check the speedo cable tommorow any other differences between Gen1 and Gen2 SW20s
mr2--mad
Postby Adamal » Thu Feb 23, 2006 9:39 pm
Rear suspension was altered to make the car sit a bit lower in the back (If I recall correctly)
Also, if you're not going to change the gearbox as well, then don't worry about the speedo cable. Don't listen to Al, he doesn't know much ;)
Postby mr2--mad » Thu Feb 23, 2006 9:41 pm
thank s :D putin a 1990 mr2 turbo motr into a 1992 mr2 turbo car doesnt seem that radical i just wanna be careful
mr2--mad
Postby Al » Thu Feb 23, 2006 9:42 pm
My bad I thought you had an n/a for some reason, and the 1992 onwards sw20 turbos had an electronic speedo drive. If you already have a gen2 I'm assuming you are going to use your existing gearbox.
Al
Postby mr2--mad » Thu Feb 23, 2006 9:44 pm
correct same gearbox Waitakere drift stages for life
mr2--mad
Postby no_8wire » Thu Feb 23, 2006 10:21 pm
The way it was worded I wasnt sure if he meant the motor type...eg Gen1 mr2 motor type ( the motor being a 3sgte,meaning a gen 1 3sgte) and the car being a gen 2 sw20...etc etc...but now he know the answer so its irrelevent
no_8wire
Postby Adamal » Thu Feb 23, 2006 10:27 pm
no_8wire wrote:Gen1 mr2 motor type ( the motor being a 3sgte,meaning a gen 1 3sgte)
Ahhh ah ah ah.... The first generation of 3S engines was before the SW20 came along. The first generation of SW20's received the second generation of 3S's.
Postby Akane » Fri Feb 24, 2006 2:45 am
that Akane guy has a Gen 1 MR2 engine in his Gen 2 MR2, so I don't see what the problem is, he did have to change some of the sensor's over though.
Postby no_8wire » Fri Feb 24, 2006 7:27 am
Exactly!!!Thats what no_8wire was trying to say...If he was talking about gen1 for the motor type, he would be chucking in the wrong one!
ah that feels better...
no_8wire
Postby Adamal » Fri Feb 24, 2006 8:34 am
Adamal is pretty sure that no_8wire was talking about the engine out of a Gen 1 SW20 :P
my thinking.......ouch!
Postby mr2--mad » Fri Feb 24, 2006 1:41 pm
i never new aw11s came out with 3s engines, opps(i think thats where we went on a tangent )
i saw a site somewhere that said my frame number sw20 0068265 was in the range of gen 2 cars (it has original 3sgte (not for long))
the reconditioner im buying the engie off said he remembers the car being the rounder model mr2 so i think ill just buy it and see if all the little holes line up
Thanks everyone :D
mr2--mad
