4age - fitting new extractors, help?
Postby RickGT » Sun Feb 26, 2006 5:41 pm
anyone had any problems of the studs breaking, cause im fitting new coby extractors and dont want to risk breaking them, if they are known to break im just gona go buy all new 1's
MX73 GLXi Cressida 1JZ-GTE
EP91 Glanza V
RickGT
Postby AE85coupe » Sun Feb 26, 2006 6:11 pm
i never had any problems with them breaking, just be careful, its not hard
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby Jebus » Sun Feb 26, 2006 6:13 pm
Nup youll be fine, unless youre a complete monkey.
Jebus
Postby Ae92typeX » Sun Feb 26, 2006 6:21 pm
could always make sure you wd40/crc/etc them the night before also
Ae92typeX
Postby RickGT » Sun Feb 26, 2006 10:40 pm
sweet cheers guys
what sort of power increase would i expect to see, more down low right?
EP91 Glanza V
RickGT
Postby Jebus » Sun Feb 26, 2006 10:58 pm
RickGT wrote:sweet cheers guys
Not much, and quite the opposite
a) Cobys arent flash, theyre press bent so arent terrific. But ok for the price you pay.
b) As a general rule
4-1 = Higher top end
4-2-1 = more bottom end
Cobys are 4-1
c) They arent tuned length so arent outstanding on a stock motor
d) They dont have a hole for the O2 sensor, so unless you can fabricate something to fit that in, it will run worse than when you began.
Also, how do you plan to connect them to your existing exhaust? Youll need a hacksaw to cut the existing exhaust, and a welder to join the exhaust and extractors, if ya cant do this youll need to get a muffler shop to do it. It WILL be loud (very loud) driving it to a muffler shop with just extractors.
Jebus
Postby RickGT » Mon Feb 27, 2006 10:23 am
so what are these rage 1's like then?
EP91 Glanza V
RickGT
Postby Jebus » Mon Feb 27, 2006 11:03 am
RickGT wrote:so what are these rage 1's like then?
Well, I have no idea, how about you elaborate a little bit more?
Jebus
Postby RickGT » Mon Feb 27, 2006 11:05 am
well i rang up my local garage and they said we can get coby or rage, she said the rage 1s are usually more expensive so im guessing they prob bit better, any1 herd of this brand. what other extractors are out there for 4age?
EP91 Glanza V
RickGT
Postby Jebus » Mon Feb 27, 2006 11:09 am
Do some research yourself and find out, if you searched you would have found out that one of your best options is standard 20V extractors, slightly modified to suit. Or even better save the $200 and leave the stock ones.
Also you dont need a new thread on wether to go 4-1 or 4-2-1. I outlined it for you above and its been covered many times before.
Have a search.
Jebus
Postby ChaosAD » Mon Feb 27, 2006 6:37 pm
Do a search on coby extractors. In my experience the FWD 4age ones are absolute junk. shoddy workmanship and not tuned/dyno tested or anything. put some on my fx and lost power. DONT DO IT
Perhaps look into a factory 20v manifold.
ChaosAD
Re: 4age - fitting new extractors, help?
Postby Crucible » Mon Feb 27, 2006 8:31 pm
RickGT wrote:anyone had any problems of the studs breaking, cause im fitting new coby extractors and dont want to risk breaking them, if they are known to break im just gona go buy all new 1's
Just a side note, Most coby extractors are painted red, that paint flakes off a soon as they get hot, looks real untidy. It Pays to burn off with a gas torch prior to fitting and repaint with some high temp stuff like vht etc....
just my 2c
TNT
Crucible
Real Life Mechanic
Postby no_8wire » Mon Feb 27, 2006 10:10 pm
I have a set of blacktop headers for sale...already modded to suit a 16v 4age...complete with 4-2 and 2-1 sections...
Its the best you can get... 8)
no_8wire
