4age blue/redtop intake sensor compatibility
Postby l1ttle_d3vil » Sun Feb 26, 2006 7:57 pm
hey, I just got a redtop 4age out of an ae92 levin with a rwd bluetop (stock standard) ae86 (or corona) throttle body on it.
only problem is the redtop loom doesn't fit the sensors on the bluetop manifold. Can I swap the redtop sensors [TPS, cold start etc] over onto the bluetop manifold, then use the redtop loom and ECU without any problems?
-matt
Postby l1ttle_d3vil » Tue Feb 28, 2006 6:36 pm
bump. sorry of this has already been covered..
Re: 4age blue/redtop intake sensor compatibility
Postby matt dunn » Tue Feb 28, 2006 7:38 pm
l1ttle_d3vil wrote: Can I swap the redtop sensors [TPS, cold start etc] over onto the bluetop manifold, then use the redtop loom and ECU without any problems?
-matt
If it physically fits, ( which it should )
then yes you can.
