manual soarer
manual soarer
Postby turbo » Sun Feb 26, 2006 10:09 pm
my soarers bot 2 cum in to the country and i wana have the manual parts ready 4 her so wot do i need
turbo
Postby Ae92typeX » Sun Feb 26, 2006 10:14 pm
gearbox
flywheel
bellhousing
slave/master cylinder & lines
pedal box
spigot bearing
driveshaft
clutch & pressure plate
Im sure Im leaving stuff out, but thats a lot of it
Ae92typeX
Postby Jebus » Sun Feb 26, 2006 10:33 pm
Thats about it, but youll also need interior panels, g/box crossmember and gearbox and clutch fluids.
Jebus
Postby gepsk8 » Sun Feb 26, 2006 11:10 pm
hey, i sort of know the guy who converted babe blue soarer and its not cheap. custom drive shaft i know, custon gearbox member. budget at least $1500 dollars.
gepsk8
Postby Ae92typeX » Sun Feb 26, 2006 11:13 pm
x members are easy enough if you can do some fab work yourself.
its not recomended to alter a driveshaft yourself for road use though. I had one made up afew years back for about $300ish
Ae92typeX
Postby Si » Mon Feb 27, 2006 12:11 am
What sort of soarer exactly?
im assuming jzz30, but.........
Current: , '96 SubaruImpreza
Si
Postby Silent Knight » Mon Feb 27, 2006 7:19 am
If it's a JZZ30 and you want to do it properly with a proper gearbox so that you don't need to modify your shifter then you need to bargain on around 1200-1500$ for just the gearbox...
Silent Knight
Postby turbo » Mon Feb 27, 2006 12:42 pm
i knw wot i need just out of wot lol i got a budget of 3g 4 the manual and already have w58 gear box
turbo
Postby Silent Knight » Mon Feb 27, 2006 12:53 pm
Ok well a quick list of what need is:
Gearbox with Bellhousing.
Clutch + Break Pedal Box.
Master + Slave Cylinder and Clutch line.
Gearbox + Clutch Fluid.
Clutch + Pressure plate.
Thrust bearing + Spigot bearing.
Clutch fork.
Gearbox crossmember.
Driveshaft. (MKIV N/A Supra driveshaft from memory is a straight fit.)
All the little nuts and bolts.
Manual Centre Console.
Then you just need to bridge the inhibitor (sp?) and wire the reverse lights if you are still going to be using your auto ECU.
That should cover it all. :wink:
Silent Knight
Postby AE91Sprinter » Mon Feb 27, 2006 6:00 pm
turbo wrote:i knw wot i need just out of wot lol i got a budget of 3g 4 the manual and already have w58 gear box
** AE91Sprinter struggles to understand foreign language....
AE91Sprinter
Postby Undertow » Mon Feb 27, 2006 6:04 pm
Just buy my Soarer. 10k and she's yours babycakes.
トヨタソアラドリ
http://www.geocities.com/weareallameric ... bobis.html <---the greatest website in the world.
CT12s are shit.
Undertow
Postby Si » Mon Feb 27, 2006 10:11 pm
please read the animated image in my signature.
thanks.
Si
Postby gepsk8 » Mon Feb 27, 2006 11:16 pm
oh, yea speedo's an ass if u have a digital dash. atleast i know got the coin to do it right no back yard job, with driveshaft.
gepsk8
Postby turbo » Tue Feb 28, 2006 11:05 pm
ok ill write it out for si. i know what parts i need i just heard you need a pedal box from a old supra or something like that and what do i get the rest of it out?.
turbo
Postby Mr.Phreak » Wed Mar 01, 2006 10:48 am
Why not get the gear from a Manual Soarer :P (Still assuming you're talking about a JZZ30)
Mr.Phreak
