Where do I go, to get Automotive/Toyota nuts/bolts etc?
Postby RomanV » Mon Feb 27, 2006 2:42 pm
I need a few nuts, bolts, and clips.
eg. Bolts that hold the cross member to the car.
Clips that hold the door skins to the doors.
Where would I go to get stuff like this?
My local Toyota dealer?
A wreckers?
Warwick?
Postby pc » Mon Feb 27, 2006 2:45 pm
I havn't been to pick-a-part in AKL but would assume it has more than in WLG. There should be something there with all the bolts that you need.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby Mr Revhead » Mon Feb 27, 2006 3:05 pm
yeah i can do clips. but they are a pita
for bolts try an engineering supply outfit. toyota use 1.25 ptich on most things
Postby Jebus » Mon Feb 27, 2006 3:08 pm
Clips see Warwick, or find someone wrecking one or if youre lucky one at a wrecker. Repco etc have the twirly stand with the UDF High tensile bolts etc in assorted lengths, wll be cheaper than an engineering shop. Or find someone with a bucket full of bolts theyve collected over the years from pulling things apart and raid them, such as myself ive got shitloads of em.
Jebus
Postby AJz » Mon Feb 27, 2006 3:52 pm
repco have most of the interior trim clips i think you are talkin bout, but i hope you know someone who works there.....they big $$$$$
I had vtax :(
AJz
Postby fangsport » Mon Feb 27, 2006 5:36 pm
if you go to an engineer, chances are, to get a metric thread and pitch, you'll end up with an imperial head, or 1mm up from Japanese sizing.
go for a scrounge at the local wreckers, some even sell misc. bolts by the container.
fangsport
Postby Mr Revhead » Mon Feb 27, 2006 5:46 pm
ah... no... i got all my bolts from a local bearing/tool supplier and they were all metric.......
Postby fangsport » Mon Feb 27, 2006 5:57 pm
Mr Revhead wrote:ah... no... i got all my bolts from a local bearing/tool supplier and they were all metric.......
but was the head and thread sizing the same as Toyota bolts?? most of the ones i discarded from usable eg were 6x1.25 with a 13mm/1/2" head or 8mm x1.25 with a 15mm/5/8" head.
fangsport
Postby Mr Revhead » Mon Feb 27, 2006 6:09 pm
yep were all metric.
plain bolts and high tensile as well
Postby fangsport » Mon Feb 27, 2006 6:24 pm
Mr Revhead wrote:yep were all metric.
i must be going to the wrong suppliers then :cry:
fangsport
