It has been suggested by a few people that I just ditch the afm and std ecu and go for aftermarket. I have no experience with Link but know a few cars running LEM.
I would like to use the tvis setup (already using the manifold minus butterflies) which should help with bottom end and lag. But the gze ecu doesn't have the output.
Instead of using a stand alone rev switch and spending money on dyno time to try get the afm tuned (if that is even the fueling problem). I have been thinking maybe it would be best in the long run to install a LEM.
What I would like to know is:
- Can the LEM be tuned well enough for efficiency as well as max torque and hp.
- Are there enough outputs on the (non-plus) Link for rev switch (for tvis) as well as high and low boost switch and anything else I may need.
- Is the link loom a complete replacement for the standard engine loom? (If it is then I could sell off the complete loom and ecu for a few bob).
- Is it even worth going aftermarket or should I persever with the Std ECU and AFM.
Car is intended for weekend track use as well as daily. Gotta have something to beat the rest of the family!
