Not your average tech question
Postby Steve123 » Tue Feb 28, 2006 7:44 pm
Does anyone know for sure if Estimas have asymetric beam headlamps? I rang Toyota and they said they do. However Ive now checked a total of of 6 2nd hand heaplamps, ( some provided by wreckers etc) and they all have random blury beams which will not pass a WOF. Cheers
Steve123
Postby Mr Revhead » Tue Feb 28, 2006 9:35 pm
theres many differnt headlamps for those.
i think a lot are plastic which can discolour, tried polishing with brasso?
Postby diss7 » Tue Feb 28, 2006 9:41 pm
I wouldn't use brasso
Meguiers (spelling) have a product called plastix. Its a plastic polisher. We used it my my partners glanza and they came up very very well.
diss7
Postby Alex B » Tue Feb 28, 2006 9:47 pm
Ive used brasso on dads cefiro, they came up mint.
Postby Steve123 » Tue Feb 28, 2006 10:17 pm
Thanks for the suggestion but polishing wont help in this case. The lenses are clean and clear.
Steve123
Postby Mr Revhead » Wed Mar 01, 2006 11:38 am
brasso works suberb on plastic lenses.
iv yet to find anything better.
so if they are clean and clear whats your problem??
whats casueing the beam issue??
Re: Not your average tech question
Postby Crucible » Wed Mar 01, 2006 12:19 pm
Steve123 wrote:and they all have random blury beams which will not pass a WOF
To my knowledge the only things that will produce a scattered pattern on a beam setter is a dull outer lense, like suggested, or a bulb that hasnt been fitted into the locator properly.....
Crucible
Real Life Mechanic
Postby Steve123 » Wed Mar 01, 2006 8:47 pm
Mosture or a faulty internal reflector will cause it too
Steve123
Postby 10k 20v » Wed Mar 01, 2006 10:39 pm
is this a projector style lamp, if it is they have a beem pattern that stays mostly flat with a rise at the centre line which then heads of to the left flat.
A bit like the picture below. It's crude i know but it gives you an idea.
I have struck bulbs that have a bent filament, incorrect installation, mositure, dull lens.
Thats pretty much it.
Sometime the cut off on these headlights isn't that noticable.
10k 20v
Users browsing this forum: No registered users and 30 guests
