Compression ratio
Compression ratio
Postby JP0976 » Wed Mar 01, 2006 5:38 pm
This afternoon i tested my compression ratio on my 4age and came up with 152-157 across all 4 cylinders.
what i want to know is how you figure out what compression ratio that is like when you see 11.0:1 and the like.
Any help muchly appreciated
JP0976
Postby pc » Wed Mar 01, 2006 5:48 pm
What you have measured is the 'compression' which is not the 'compression ratio'.
Pull the head off and measure all the empty space in the cylinder/head/headgasket etc. Then work out the ratio of that space from TDC to BDC.
If its a stock engine then it will be a stock compression ratio... which is reasonably well publicised and easy to find... about 9.4:1 for a bluetop (i think)
AFAIK there is no way of working out compression ratio from the compression test as all engines are different and there is no direct correlation between the two.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby $CENSLS1$ » Thu Mar 02, 2006 9:25 am
Very well put mate :)
TeamPoon~Building Sex on wheels since '06
$CENSLS1$
