shock lengths, gx71 / ae85 etc
Postby eightytrueno » Wed Mar 01, 2006 7:46 pm
ok so i have cut springs in the mark II, and its wof time.
the rears are still captive but the front are not
i'm on a stupidly small budget. i was wondering if anyone knows what shocks are about 2" shorter than the factory GX71 shocks, and i would be able to chuck in the front to ensure that the fronts become captive again? possibly ae85/6? or other toyota ones?
ollie
eightytrueno
Postby z|gen » Wed Mar 01, 2006 8:41 pm
bit of a stupid idea to cut ya springs when ya have a wof due..
its probably cheaper and easier to buy new springs from a gx71 - as these are common as $&#$% to put in for the wof, then put your cutties back in if you have to.
AE91 SUPERCHARGED COROLLA
z|gen
Postby MrDori » Thu Mar 02, 2006 8:28 am
im in the same stiuation, ae101 shocks are alot shorter, so are sw20 mr2 rears, this is what im doing with my mark II, you will have to shorten the hole strut tho, cutties are pretty shit, still make it ride like a boat just a lower one
MrDori
Postby eightytrueno » Thu Mar 02, 2006 8:38 pm
actually cut the springs just after i had my last wof, drove round on them for a while, left the country, come back and its wof time again gutted!!
cheers i may try ae101 shocks then
eightytrueno
Postby AE85coupe » Thu Mar 02, 2006 8:56 pm
AE92 shocks are shorter too man, by about 70mm
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby Caveman » Thu Mar 02, 2006 10:58 pm
If you want ae92 shocks i have some you can buy cheap
Caveman
Postby KE20 » Fri Mar 03, 2006 10:03 pm
just run the standard shock and get it shortened.
Garage Dori
KE20
Postby Logan » Sat Mar 04, 2006 8:39 am
Just rebuild the standard wet shocks with some ATF fluid or manual transmission or the likes, put some spacers over the shaft to restrict the stroke (pvc pipe/heater hose etc). Put em back together and tickety boo, no falling out springs and shocks that work
SR Sold. Onto Other Things
Logan
