4AGTE
4AGTE
Postby CAMB01 » Fri Mar 03, 2006 8:47 pm
Hey all can someone give me in great detail how extract 400 flywheel horsepower out of a 4AGZE please?
So far i have a GZE block which is bored out 0.5mm with toyota 0.5mm oversized forged 9.0:1 pistons
GZE crank
Poilished shotpeened and balanced rods.
Going to balance the rotating assembly
Have a small port cylinder head and manifold.
Dont have a turbo or an exhaust manifold yet.
0.8mm TRD steel shim head gasket.
Will be using an aftermarket computer, dont know what yet.
If someone can share with me what i need to do, and get that would be great.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby CAMB01 » Sat Mar 04, 2006 12:30 pm
bump
CAMB01
Postby Ako » Sat Mar 04, 2006 12:58 pm
Open your wallet
WIDE
Ako
Postby CAMB01 » Sat Mar 04, 2006 2:49 pm
Well i am capable with building engines as i work as a motor machinist.
I realise the turbo is going to be the expensive part.
Im willing to take my time with this engine, collecting parts as i go
CAMB01
Postby ATAl » Sat Mar 04, 2006 2:56 pm
Just general things:
Lower the compression -> stock headgasket and 8.5:1 pistons.
Get huge injectors and upgraded fuel pump and maybe fuel lines.
Probably need to port the head, maybe get bigger cams. (Possibly use a big port head?)
The conrods may need replacing with something stronger.
Turbo capable of 400hp.
Also engine will probably need cooling system upgraded because of the extra heat generated.
This will result in a engine which will highly likely be so laggy it will be useless for all but dragging, and probably not all to reliable. But if you are building an engine just for racing this will probably do the trick.
ATAl
Postby evil_si » Sat Mar 04, 2006 3:32 pm
id stick with the compression you have, get a decent fuel system. pumps, surge tank and fuel reg capable of doing the job. id personally look at sx items.
turbo wise id think something along the lines of a .70 compressor .69-.80 turbine.
how about running a 20v head?
id go any talk to andre at speedtech. he may shed some light on what you need to do, after all he does have a 500 atw, dx with a 4age base.
evil_si
Postby CAMB01 » Sat Mar 04, 2006 4:07 pm
i forgot bout the fuel system. have thought about getting a surge tank.
CAMB01
Postby CAMB01 » Sat Mar 04, 2006 9:45 pm
Im going to use the 16 valve head
CAMB01
Postby Dell'Orto » Sat Mar 04, 2006 9:52 pm
Bottom end is fine, though you'll need something like a TD06 to flow enough for 400hp :? I think TIMID used a GT35/40 didnt it? Basically hand-me-downs from DOCILE :lol:
Postby CAMB01 » Sun Mar 05, 2006 12:32 am
What sort of price would i be looking at for a TD06 or a turbo in good condition to flow that sort of power?
I'm not worried about drivability as it will be used mainly for drag racing
CAMB01
Postby CAMB01 » Sun Mar 05, 2006 4:31 pm
bump
CAMB01
Postby CAMB01 » Sun Mar 05, 2006 9:10 pm
bump
CAMB01
Postby Al » Sun Mar 05, 2006 9:27 pm
GT3071R should do the trick, the smallest ex housing is the 0.63
Should run you around $1300ish USD ($2k nzd) + shipping, usually always cheaper to source it yourself than pay some monkey $500 ontop of retail :)
Al
Postby Crucible » Sun Mar 05, 2006 10:38 pm
The turbo Im using is a T3/T4 Hybrid, Told it would support 530 hp, .70 Exhaust and T04E Comp Housing,..A/R?, The turbine is "o" Trim and the Comp wheel size = Exducer: 2.23" Mayor : 3.31. An "S" or 60-1 Comp wheel are supposed to be yet more efficient. :lol:
From what Ive read on here a TD05-16g is a cheaper bang for your buck and can support over 400hp.
:lol:
Crucible
Real Life Mechanic
Postby Al » Mon Mar 06, 2006 11:54 am
True-No-Turbo wrote: From what Ive read on here a TD05-16g is a cheaper bang for your buck and can support over 400hp.
:lol:
Maybe on 30psi :?
Al
Postby EVLGTZ » Mon Mar 06, 2006 4:02 pm
heh yeah lol
would do it on a 2ltr
On a 1600 however I think 400hp from a td05-16g would be bit of a stretch
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby Bazda » Mon Mar 06, 2006 4:56 pm
GT35/40
272 grind cams
bigger valve springs and valves
port n polish
8.5:1 compression
shot pein rods
custom inlet
25psi shoudl see u at the 400hp mark easy :D
Postby StuartM » Mon Mar 06, 2006 5:44 pm
i reccomend the megasquirt-II (v3) ECU. mine cost well under $500 and its very, very tunable.
RPM signal can be tricky to wire up, but there is new firmware in the works that should address that.
StuartM
Postby Caveman » Mon Mar 06, 2006 5:47 pm
Does megasquirt II v3 control spark?
Caveman
Postby StuartM » Mon Mar 06, 2006 5:51 pm
yes
StuartM
Users browsing this forum: Bing [Bot] and 7 guests
