cam timing marks aw11 4agze-now with idle probs
Postby Psycho_Dad » Fri Mar 03, 2006 11:00 pm
ok im attempting to install a cambelt on a 4agze on my aw11...
i can see the mark on the crank where tdc lines up easy, but where to i find the marks for the camshafts? im guessing somewhere on the camgears their is a nic or white paint and on the inner timing cover their is a mark their im suppposed to follow? i really wanna get this car on the road i have had it for 2 months and still not drivable grrrrr
any help terribly apreciated, id allmost pay for pics
Peace
Psycho_Dad
Psycho_Dad
Postby slighty_sykotic » Fri Mar 03, 2006 11:34 pm
The marks are two "dot" like thing. Basically a impression.
On the cam gears, should be real easy to see (one cam may have two dots..)
--Sykotic
slighty_sykotic
Postby 85AW20v » Sat Mar 04, 2006 8:21 am
And also looking in through the oil filler hole, you should see an indent on the inlet cam when its lined up right.
See ya
Simon
85 MR2 20v
85AW20v
Postby slighty_sykotic » Sun Mar 05, 2006 7:36 pm
I had trouble seeing that indent in the oil filler cap... Like, I couldnt find it.
My car runs fine though just using the other two marks.
--Sykotic
slighty_sykotic
Postby Psycho_Dad » Sun Mar 05, 2006 8:21 pm
yeah found the groove, hiden under a dot of white paint that i couldnt see under workshop light.. , now car starts and doesnt idle, well does when cold, but stalls when warm, i havnt done the timing but took it for a drive and it seems like the supercharger isnt working at all... again would that be timing? damn cars starting to stress me out... 2 months driven only a handfull of times
Peace
Psycho_Dad
Psycho_Dad
Postby StuartM » Mon Mar 06, 2006 11:27 am
to set the timing, wire a paperclip between T and E1 terminals inside the diagnosis connector, otherwise the ECU will be going spark advance control.
StuartM
Users browsing this forum: Bing [Bot] and 24 guests
