holy smoke batman
holy smoke batman
Postby deaf_rattle » Sun Mar 05, 2006 1:56 pm
Silvertop 20v
random blue smoke.
under hard acceleration.
highish ks
fixable or dont worry?
running magnetic at the moment
Postby CozmoNz » Sun Mar 05, 2006 2:07 pm
go downhill engine brake, plant it at the bottom :), see how much blue you get there.
Rayne For President!
CozmoNz
Postby deaf_rattle » Sun Mar 05, 2006 2:10 pm
pretty common with 20vs is it?
Postby AceSniper » Sun Mar 05, 2006 3:30 pm
stick with 15/40 unless ur not using much oil
yea prolly just a mix of overfuel an a lil oil
wouldnt call it a problem unless ur using heaps of oil (check heaps so u dun run a bearing) or real bad compretion
AceSniper
Postby fuel » Tue Mar 07, 2006 10:49 am
Do a compression test, that would give you an indication of the piston ring condition.
There's a couple ways to 'fix' this. The best and most expensive option would be to tear down the engine and replace the rings, bearings etc. You could switch to a thicker oil say 15W50, but that's not recommended for a high revving engine. Or a cheap alternative which may work is to use an oil additive - not the ones which work by thickening up the oil, but the ones which contain PFTE. I used Nulon worn engine treatment in my Galant with over 400,000kms on the clock. It used to burn about 1L of oil every 1000kms or less. I chucked that stuff in and I haven't had to top it up for 3000kms. Even though it would chew through the oil, I would never really see it puff out blue smoke unless I absolutely raped it.
LOUD NOISES!!!
fuel
Users browsing this forum: No registered users and 29 guests
