Rob wrote:Had a simillar problem, took it to a sparky and they took about 3 months to rewire the fuel pump straight to the air low meter instead of through the really, so check your power to your pump.
It does not take 3 month to rewire fuel pump, also if you connect the AFM contacts directly to fuel pump, there possibility of burning off the contacts.
Why they did not replace fuel pump relay or wiring whichever was faulty in first place? Ohh well there are plenty auto sparkies that don't know what they are doing (or don't want to do it properly because it does not pay).
if car stalls on idle it pays to check if you don't have any vacuum/air leaks.. you can check if the sensor is faulty using multimeter, it should be arround couple of kiloohms at room temperature (and decrease with increasing the temperature)...
