ECU Numbers for bluetops
Postby crispy'86 » Tue Mar 07, 2006 12:29 pm
I've done a search but haven't found the appropriate info i need.
I need Ecu numbers for AE82 FXGT, AW11, and AT160 Celica guys. Pretty much ALL ecu numbers and what they are off. I need to get the right ecu from my spares to get the race car running.
crispy'86
Re: ECU Numbers for bluetops
Postby matt dunn » Wed Mar 08, 2006 12:06 am
crispy'86 wrote:I've done a search but haven't found the appropriate info i need.
Doesn't really matter too much,
they all work the same.
Some just have different rev limiters etc, but they all ahve the same connectors etc etc and will plug in and run the car fine.
Matt
Postby crispy'86 » Wed Mar 08, 2006 12:11 pm
Matt
In saying that Matt an ae82 fxgt ecu won't run my ae86. I was under the impression it needs to be matching numbers . Tried this a while back now
crispy'86
Postby l1ttle_d3vil » Wed Mar 08, 2006 1:03 pm
my understanding is that fwd and rwd ecus have different pin "layouts" so they are not interchangable unless you change your loom to suit. I have got about 4 different rwd ecu's all with different numbers on them and they all run my rwd bluetop without any problems.
if you swap a few wires on a rwd loom round to suit the fwd ecu it will probably run fine.
Postby crispy'86 » Wed Mar 08, 2006 5:39 pm
l1ttle_d3vil wrote:my understanding is that fwd and rwd ecus have different pin "layouts" so they are not interchangable unless you change your loom to suit. I have got about 4 different rwd ecu's all with different numbers on them and they all run my rwd bluetop without any problems.
Yeah most likely the case
crispy'86
Postby crispy'86 » Sat Mar 11, 2006 12:27 pm
What about the different pin outs on a couple of the connectors between the fwd ecu's though?? Would it stop the engine from running. I.e. spark advance, injector switching?
crispy'86
Postby ae82gt » Sat Mar 11, 2006 3:35 pm
ae82 - 89661-12031
fxgt ae82 20v
fxgt ae101
ae82gt
