by Ako » Thu Mar 09, 2006 3:31 pm
Iiiiiinteresting....
$$%, I should have kept those cams in hindsight. Damn and blast - they're making good numbers, and I've got the extra fuelling available to try and push the turbo a bit closer to being efficient!
Oh well... Gonna be good to pull the string on this wee puppy and see what it can pull out. 300hp atw is the honest goal, on pump gas (avvy if need be, its a weekend toy).
Do you honestly think its worthwhile going to the N/A cams to help achieve this? I know the setup in this car isn't ideal, BUT right now I'm more interested in just getting it going, and seeing what happens.
I'll give you the rundown on what it has now anyway -
SARD 280LPH in tank pump
Turbo (as you know) is a TD06-25G, externally gated.
Stock intake mani, I'm going to remove the TVIS system or at least have it left open 24/7
GReddy side mount intercooler with a fan on the back of it
Exhaust is a 3" straight through affair
Intake will be a pod mounted in the side venty thing - turbos perfectly sited to do this and im not going to do much better for cold air.
ECU is the stock unit (stupid wallet is a bit empty)
Has a pair of extra injectors on the inlet, just prior to the TB. Control of these is by a GReddy sub injector controller, RPM or Boost activated - not ideal but better than nothing - haven't checked the size of them, but even if they're 300cc its still enough extra fuel for my aims.
Rest of the fuelling is stock - 440's, stock reg etc
Engine is internally stock apart from a new head gasket.
I'm waiting on your guys' advice as to whether or not the cams should get switched - you've all had a lot more 3SGTE experience than I have.
Long story short - I don't want to lean particularly hard on this engine. I'd rather have something with around 200kW atw which isn't a time bomb, than try and push it into the 230-240kW zone but have it on the ragged edge of reliability - unless this is genuinely possible. Too much power is no bad thing.
I know the setup is far from ideal, but I know it can be made to work fine - it did for 3 years on kiwi pump gas before! Apparently the dyno pull it got after arriving in country was just shy of 400hp atw, on 96 octane...
