SW20 3SGTE: while my motor is out...
Postby Pies » Thu Mar 09, 2006 6:34 pm
what should i be replacing while my motor is out?
head gasket, waterpump, cambelt, tensioner, what else?
any head work i could look at doing?
Current Rides:
Pies
Postby Adydas » Thu Mar 09, 2006 6:52 pm
Want my parts list.. cover EXCATLY what you need.
317 bucks i think of parts.
Bearing
tensioner
belts
cambelt
head gasket
Water pump
thermostat
Rotor
dizzy
leads
plugs
( Valve stem seals dependingon ages and $$ )
head rebuild and clean. make it look all sexy like this think it was about 400 bucks all up for Valve steam seals, labour and other seals and a head gasket.
BLOODY cheap im WELL impressed, and highly reccomend carrying out the work if the motors of ages and you can afford it. Got a full clean, all the clearances etc checked.
Adydas
Postby Malcolm » Thu Mar 09, 2006 6:56 pm
swap the downpipe and turbo for something better :)
don't bother touching the head, do valve cover gasket and replace the screws with bolts, pull the coolant hose that comes out of the back of the block at #4 cylinder off and check if it's blocked up (2 out of 3 of my 3sgtes have been!), if it has high km's then replace the hose from hell. Replace thermostat too
Postby Malcolm » Thu Mar 09, 2006 6:58 pm
oh yeah, replace head bolts (either with OEM or ARP)
Postby Adydas » Thu Mar 09, 2006 7:00 pm
My heads horney!! Admit it Fours!!!!!!
Adydas
Postby RomanV » Thu Mar 09, 2006 11:44 pm
Mine's better. :P
Fake edit: Erm... you're talking about the engine head right?.... :? :?
Postby Malcolm » Fri Mar 10, 2006 12:01 am
Adydas wrote:My heads horney!! Admit it Fours!!!!!!
haha yeah, when I said not to touch the head I didn't mean not to do what you did, but not to do any porting/polishing etc :)
Postby Pies » Sun Mar 12, 2006 7:20 pm
sweet cheers guys
thanks for the list adydas, who did all the work for you? did you do bits yourself or did you send it away?
Current Rides:
Pies
