4AGE starter size
4AGE starter size
Postby Caveman » Sun Mar 12, 2006 11:43 pm
Does anyone know if there is a physical difference in size the the difference 4a starters? I have the small port 2KW starter, im looking for a smaller one though so I have more clearence for the manifold
Caveman
Postby Ae92typeX » Mon Mar 13, 2006 8:13 am
I remember a while ago Matt D said there was two sizes- mostly the big one, but the later small port had a smaller one I think.
Ae92typeX
Postby RedMist » Mon Mar 13, 2006 8:25 am
20 valves have a similar size, if not slightly smaller. However the mounts are totally different.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Caveman » Mon Mar 13, 2006 9:40 pm
OK thanks.
I was going to use my exsisting housing and mounts, and just try find a physically smaller motor.
Caveman
Postby matt dunn » Mon Mar 13, 2006 10:02 pm
there are three types that fit,
the common 4age one,
tand the smaller and more powerful planetry gear reduction one found on the smallport n/a's.
There is also another gear reduction type like found on the fwd 3sge's that will fit, but unsure what engine it comes from in factory form.
So it sounds like the one you have is the smallest unless you make something.
Matt
Postby Caveman » Mon Mar 13, 2006 10:08 pm
Yes I have used a 3S started on my mates 4age, worked sweet as.
I was going to thread the other side of the bell housing and stick it there, but the external oil drain is there.
Im going to have a pick-a-part hunt, will let yous know if I find anything
Caveman
Postby fangsport » Mon Mar 13, 2006 11:49 pm
the 3T reduction are also quite small, i think they could have the same solenoid and windings as a redtop and 1G
fangsport
Postby bluemaumau » Wed Mar 15, 2006 6:57 pm
sorry tohijack but does any one know if i can replace the 4agze one with a 4afe one? :?
