5e head on 4efte
5e head on 4efte
Postby 20v_rollaboy » Mon Mar 13, 2006 6:46 pm
How will this help/improve my engine?
Is it a straight bolt off bolt on job or do other things have to be changed?
And will this increase engine capacity?
Thanks
20v_rollaboy
Postby loose_unit » Mon Mar 13, 2006 8:27 pm
No, the heads are the same, so it wont help. The pistons are different in the 5E which is what adds the extra compression. 4e-fte 8.2:1, 5e-fe 9.4:1, 5e-fhe 9.8:1.
A 5e-fe with 4e-fte pistons would net a 1500 with compression in the high 8's, although theres no reason why you cant turbo a stock 5e if its tuned right.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
