Water level sensor
Water level sensor
Postby GT4 20 » Wed Mar 15, 2006 4:43 pm
After some thought, I decided that the easiest option was to utilise the washer bottle unit for the supply for the improved water spray unit I'm working on.
I'm not sure if it is Group A specific, but at the very bottom of the reservoir is a separate unit which feeds the cold start water injector. It's capacity is pretty small, so I decided to open it up to the main unit and install a level sensor at the same time.
Here is the level sensor taken from a water spray bottle used on a Subaru STi...
I started by making a circular hole at the very bottom of the reservoir to suit the sender unit and then cut a square hole (easier to make) between the two sections...
Once done, the unit was flushed out thoroughly to remove any plastic swarf. Don't want to jam a pump or block a spray nozzle! The seperate reservoir is clearly evident in the pic below.
The sealing grommet was then put in place..
... followed by the sensor itself...
A view from the top...
Plan is to utilize the OE cold start water pump which will be triggered via a relay by the Cusco water spray controller. This in turn will be boost pressure activated. I'll write more when I get to that stage.
Gary
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby Adydas » Wed Mar 15, 2006 5:32 pm
Looking good gary, Will this effect the sprayers for the windscreen?
Adydas
Postby GT4 20 » Wed Mar 15, 2006 5:38 pm
No. Screen washers use a different pump which isn't shown in the pics. The pump which is shown is for the headlight washers. So there are 3 pumps in total on teh reservoir!
Gary
GT4 20
Postby Adydas » Wed Mar 15, 2006 5:57 pm
nice stuff, got dyno for before and after? id be keen to see results.
Adydas
Postby GT4 20 » Wed Mar 15, 2006 6:14 pm
I now have an inlet temp monitor to go by. Currently awaiting for my replacement pre-rad to be completed (hopefully tomorrow). Twin core unit which is twice as thick and taller too. Should make a huge difference on its own - will be interesting to see how much difference the water spray set-up works in addition.
Gary
GT4 20
