FINAL CONVERSION HELP
Postby bluemaumau » Thu Mar 16, 2006 12:57 pm
ok im about to start the conversion but before i do i wanna make 100% sure ive got everything and that everything is gonna work together.
all parts are complete
parts:
ae92 afm 4agze
ae92 gtz lsd gbox
ae92 gtz halfshafts
ae101 gt-apex hubs (front and back)
ae92 ecu and loom
ae92 engine mounts and gbox mounts
i basically have a complete ae92 gtz and a set of ae101 hubs cuz the LH front hub on the gtz is $&#$%.
is everything gonna work when i drop it into the ae101 wagon?
i.e the ae92 lsd halfshafts and ae101 gt-apex hubs?
i was talking to matt(XSVWGN) and he said id run into trouble with gbox mounts, however he using a 20v gbox (not sure if its s-top or b-top) and im using the ae92 lsd gbox.
so wat do you think?
do i need anything else?
is everything compatible?
and any hints or tips as this is my first engine conversion
cheers everyone
will
Postby bluemaumau » Thu Mar 16, 2006 4:44 pm
anybody? :? 8O
Postby 20v_rollaboy » Thu Mar 16, 2006 6:13 pm
When are you gonna start pulling the 4afe out? And when are you gonna take the gze out of the donor car?
I suggest you take the engine out of the donor car first and clean it up and check for any leaks. Also change anything if need be.
20v_rollaboy
Postby bluemaumau » Thu Mar 16, 2006 6:45 pm
yea im taking the ze out dis friday saturday then checking replacing it throughout the week then next weekend ill put it in
XSIV told me that ae92 halfshafts are too long for my project and i need ae101 lsd gtz hshafts, can anybody confirm this?
Postby bluemaumau » Thu Mar 16, 2006 9:57 pm
any1????
also out of interest a ae92 strut brace wont fit on a ae101 wagon ay? :?
please help me out
Postby Caveman » Thu Mar 16, 2006 10:03 pm
You need supercharger shafts for the supercharger gearbox. One of the supercharger shafts has an extra support mount, you'll have to get around that somehow, not sure how though. PM THA SHZ as he just put (or is putting) an e58 in his ae82.
If you in a hurry to get it done, leave your current gearbox in there and use the c50. You'll mince it but it will work until you get the drivetrain sorted. You'll have to use the smaller flywheels, etc, etc.
Caveman
Postby bluemaumau » Thu Mar 16, 2006 11:11 pm
so ill need ae101 gtz shafts (lsd)?
does anyone have a ae92 afm gze wiring diagram? :?
