Do Dizzy's leak ?
Do Dizzy's leak ?
Postby eritate » Thu Mar 16, 2006 1:54 pm
Hey something was burning on my donor car
So i left it running for a little while just to warm it up... then i popped the hood and there was steam coming from the exhaust manifold
I checked and checked but couldnt see anything until some kind of liquid came out of the dizzy cap
Ideas to what it could be ??
Oh its an ae86
eritate
Postby Leon » Thu Mar 16, 2006 2:12 pm
4age's are legendary for oil leaks from the distributor but that really doesn't sound like the issue you've got [confused]
Postby eritate » Thu Mar 16, 2006 2:33 pm
hmm well it was steam or smoke... maybe smoke because something was burning
eritate
Postby l1ttle_d3vil » Thu Mar 16, 2006 3:06 pm
Leon wrote:4age's are legendary for oil leaks from the distributor but that really doesn't sound like the issue you've got [confused]
interesting...i have that exact problem, even after replacing the o-ring. is there any way to fix it?
Postby sergei » Thu Mar 16, 2006 3:12 pm
it is probably leakingthrough bearings inside of dizzy, the only way is to dissasemble replace bearings and seal and assemble it the exact way it was.
Postby eritate » Thu Mar 16, 2006 3:15 pm
so it is common and not bad ?
eritate
Postby FXGTV » Thu Mar 16, 2006 5:09 pm
Mine smallport 4age just developed this problem. I have yet to replace the dizzy seal, but hopefully that will sort it. Its no biggie i dont think
1988 r31 TI Skyline.
FXGTV
Postby TotemoAW11 » Thu Mar 16, 2006 5:40 pm
mine was leaking, so i replace the bearing and seal, then it was fine, then it started leaking. Then I put gasket goop all over the o ring and it fixed it.. then it started leaking again.
$&#$% who cares mang, no biggie ay :)
TotemoAW11
Postby RickGT » Thu Mar 16, 2006 5:56 pm
y not do it properly, costs about 6 bucks to do, all u need is drill, solid pin bout $3, new oils seal bout $3 and bearing pullers and maybe a new bearing if its shagged, i did mine piece of piss really
MX73 GLXi Cressida 1JZ-GTE
EP91 Glanza V
RickGT
Postby ChaosAD » Mon Mar 20, 2006 1:36 pm
Problem is that the shaft is usually worn too
ChaosAD
