sw20 hesitation/timing advancement
Postby gordon77 » Fri Mar 17, 2006 9:36 pm
hey my gen 2 3s-ge has a somewhat large hesitation around the 5g mark. apart from the obvious like injector cleaner, air filter replacement and plugs is there anything in particular that could be causing this?
it has 8mm ht leads, hot guns i think so could that be a factor?
also i thought it would be a good idea to check the timing at the same time. what should it be set at to run 98 octane fuel? and if it is out how would one go about correcting it? i mean the proper way of doing it not just turning the dizzy round lol :)
What is RR?
gordon77
Postby Adamal » Fri Mar 17, 2006 11:17 pm
Gordy, mind if I give it a drive to check out exactly what you mean? Depending on how large the hesitation is, it might be the ACIS system, which adjusts the length of the runners, it changes over around there so there is a bit of hesitation.
Postby gordon77 » Sat Mar 18, 2006 12:50 pm
ohk sweet. ill replace the things in my first post if they need it and go from there :)
if it is the acis system is there a way i can make it not hesitate?
What is RR?
gordon77
