what is this? 3sge owners
Postby vr4boy » Sat Mar 18, 2006 5:52 pm
there is a part bolted on to the inlet manifold that has 4 butterflies inside, what is this? and do i need it??
1995 ae101 levin st 20v
vr4boy
Postby Dell'Orto » Sat Mar 18, 2006 6:09 pm
Sounds like the TVIS plate. You dont reeeeeeally need it, but you'll need to tweak a few things if you ditch the butterflies.
Postby vr4boy » Sat Mar 18, 2006 6:12 pm
what does it do? and what do you mean by twecking things?
vr4boy
Postby RomanV » Sat Mar 18, 2006 6:30 pm
No, its the ACIS system.
It increases the volume of air in the intake runners once you get to a certain RPM. (5xxx rpm IIRC)
Postby vr4boy » Sat Mar 18, 2006 6:36 pm
ohh yea so ishould keep it there then?
vr4boy
Postby RomanV » Sat Mar 18, 2006 6:58 pm
Yep. 8)
Your car would lose top end power if you removed it.
Postby Caveman » Sat Mar 18, 2006 11:49 pm
If hes talking about gen1 3sge or st162 then its TVIS, if its MR2 then its ACIS 8)
Theres a discussion on tvis in the FAQ section
Caveman
Postby vr4boy » Sun Mar 19, 2006 12:54 pm
its an mr2
vr4boy
Postby Malcolm » Sun Mar 19, 2006 12:59 pm
yes it's ACIS (acoustically controlled intake system). Keep it, those butterflies open at high RPM to alter the reasonant frequency of the intake system to suit the higher RPM range. I guess you could enlarge it to improve things further if you were running crazy RPMs, but other than that I'd think leaving it alone would be the best idea :)
Postby CozmoNz » Sun Mar 19, 2006 1:51 pm
RomanV wrote:Yep. 8)
youd loose low end....
high end if anything youd gain something being less restriction.
Rayne For President!
CozmoNz
Postby RomanV » Sun Mar 19, 2006 2:12 pm
The butterflys open at top end....
If you removed the ACIS system (and blanked it off) you'd lose top end.
If you just took out the butterflies, then you'd lose bottom end... but that's not what he said. :P
And they arent a restriction anyway.
Postby Malcolm » Sun Mar 19, 2006 7:17 pm
have you ever seen a 3SGE ACIS manifold? there's pics on my website under the 3sge generations section.
The second plenum is off to the side of the inlet runners, so I imagine air doesn't even flow through the butterflies, it simply changes the acoustics of the inlet. It is different from the 5e-fhe ACIS, which from what I can tell, has 2 different lengths of runners and it switches between the two with butterflies
Postby Adamal » Sun Mar 19, 2006 7:25 pm
Helmh*ltz!!!!
vr4boy's sig wrote:sw20 n/a mr2 -JSTTRY- 15.24@142.37kmh 1/4 mile
Ahhh, I've seen this one around the shore. Was behind you the other day when you pulled into Repco. The plate is fairly recent, isn't it?
Postby vr4boy » Sun Mar 19, 2006 8:09 pm
yeap would have been me, i live on the shore, car has no motor no, time to build something with some decent power, and im not to sure what you mean by the plate being recent.
vr4boy
Postby Adamal » Sun Mar 19, 2006 8:12 pm
I'm pretty sure I've seen you round before, but not with that number plate.
Postby vr4boy » Sun Mar 19, 2006 10:27 pm
ohh the plates been on it scince ive owned it (dec '04) and car was fully stock then, so just looked like any sw20.
vr4boy
Users browsing this forum: Bing [Bot] and 7 guests
