lowering springs
lowering springs
Postby trd-drifting » Sat Mar 18, 2006 7:09 pm
Wat brand of springs will lower a ma70 and i am lowering a ga70 the lowest if any one knows. Or how much do each brand of springs lower the car like mm etc.. Any help would be appreciated
trd-drifting
Postby Ae92typeX » Sat Mar 18, 2006 8:41 pm
I had jamex in my Ga, lowered it around 40mm all round.
Ae92typeX
Postby trd-drifting » Sun Mar 19, 2006 10:48 am
I was thinkning about lower than that as you know the ma70 stock looks like a 4 by 4 in height. Anything you know that goes lower. What a kings and lovels really like? Thanks anyways
trd-drifting
Postby Ae92typeX » Sun Mar 19, 2006 11:31 am
You will probably need to look at different shock's also- as any lower will just cause it to bottom out all the time.
Ive had kings on my ae92 which dropped it 45mm, and similar on another car. I didnt have issues with them, but many people find them too soft...if that was to be the case, the heavy supra would cause it for sure.
Also, Im assuming you are doing it for looks, as if it was for handeling, I wouldnt drop it much at all.
Ae92typeX
Postby Si » Sun Mar 19, 2006 3:12 pm
http://www.geocities.com/ma71supraturbo ... pring.html
that should help you with the JDM branded springs.
http://www.935motorsports.com/mk3supras ... eviews.htm
is some reviews and info
Current: , '96 SubaruImpreza
Si
