Hi
Ive got a high k's 4age I want to race, im replacing the bottom/main end bearings but wondering if its worth doing the pistons too, do the piston skirts wear against the bore? or is it just ring interface? Just trying to get a little ahead before I pull the block down. Its a bit noisey, sounds a little like piston slap right now.
Its a smallport 4age.
Thanks
