Who Does Cam Gear??
Who Does Cam Gear??
Postby mister_two » Sun Mar 19, 2006 7:54 pm
Planning to change aftermarket Cam gear on a 4age, any you guys recommend a shop who does it? ( In Auckland)
mister_two
Postby TWSTD » Mon Mar 20, 2006 12:32 pm
We can supply Fidanza adj cam gears for 4AGE (16v)
Click here!
TWSTD
Postby fangsport » Mon Mar 20, 2006 4:18 pm
Palmside do exchange gears .$250 -ish
fangsport
Postby craigt » Mon Mar 20, 2006 7:30 pm
I do exchange gears as well, $180 for the pair
craig.t@xtra.co.nz
If it doesn't fit, force it.
If it breaks it needed replacing anyway!
AE101 4AGZE
KP60 4AGTE project
craigt
Postby fangsport » Mon Mar 20, 2006 8:00 pm
craigt wrote:I do exchange gears as well, $180 for the pair
craig.t@xtra.co.nz
can you make sprockets adjustable as well??
fangsport
Postby craigt » Mon Mar 20, 2006 8:03 pm
That $180 is for a pair of adjustable 4AGE/ZE pulleys exchange
AE101 4AGZE
KP60 4AGTE project
craigt
Postby fangsport » Mon Mar 20, 2006 8:09 pm
craigt wrote:That $180 is for a pair of adjustable 4AGE/ZE pulleys exchange
so i take it as no, you can make sprockets adjustable for us with push-rod engines i.e. cam chain/sprockets not cambelt and pulley????
fangsport
Postby vvega » Mon Mar 20, 2006 11:07 pm
i can :d
v
vvega
Postby craigt » Mon Mar 20, 2006 11:28 pm
Pushrods???? aint that some of that newfangled 1950s technology stuff???
Long metal stick things that push the valves open. Gee golly, what will they think of next :p
Yep, you can make a lot of sprockets adjustable as well, some of them get a bit tight for room inside the timing cover thou
AE101 4AGZE
KP60 4AGTE project
craigt
Postby fangsport » Mon Mar 20, 2006 11:33 pm
craigt wrote:Yep, you can make a lot of sprockets adjustable as well, some of them get a bit tight for room inside the timing cover thou
no dramas there, the cover needs to be modified so the sprocket can be adjusted without pulling half the engine to bits.
what money?
fangsport
Postby craigt » Tue Mar 21, 2006 7:40 am
Would have to check, what sort of engine?
Do you have a spare sprocket I could look at?
AE101 4AGZE
KP60 4AGTE project
craigt
Users browsing this forum: Bing [Bot] and 4 guests
