All time 4WD and Full time 4WD
Postby Levin » Sun Mar 19, 2006 10:04 pm
My question is this, Is there a difference between all time 4WD and full time 4WD, and if so what is the difference.
Cheers, Tom
Levin
Postby Adamal » Sun Mar 19, 2006 10:24 pm
Same shit, different name.
Postby no_8wire » Sun Mar 19, 2006 10:29 pm
like subarus "all wheel drive" and 4wd...same systems different names that that different companies hold trademarks on I would say...
no_8wire
Postby Malcolm » Sun Mar 19, 2006 10:42 pm
generally 'all-wheel drive', like subaru uses it, has all wheels driven at all times, usually with limited slip center diffs etc. In case you're wondering, your celica would fall under the classification of all-wheel drive.
Four-wheel drive, generally, is used to describe cars which normally only drive 2 wheels, but have a second gear stick which allows you to shift into 4wd, (and usually high-ratio 4wd), or sometimes locking front hubs where you get out of the car and lock them manually.
Postby Levin » Tue Mar 21, 2006 6:49 pm
So is there a difference in the ones where you can change from fwd to 4wd and the ones that are all time 4wd? I thought there was a difference in the differentials of something....
Levin
