electronic dissy's and igniters???
Postby fangsport » Fri Mar 24, 2006 9:46 am
to save me from pulling one to bits, do electronic distributors have mechanical advance by way of counterweights?? i'll lock it up if they do.
further more, are the igniters specific to the dizzy? what i meaning is can a 2TG/3TEU/4AG etc coil and igniter be used to run a 4K electronic dizzy and vice versa?
my wee Starlet should be painted this weekend and i'll then start getting the engine sorted, so i'm raiding my parts bin to get any little gains i can :wink:
fangsport
Postby fangsport » Mon Mar 27, 2006 5:18 pm
c'mon, someone must be able to advise me before i start meddling with something i know jack about??
fangsport
Postby Ae92typeX » Mon Mar 27, 2006 6:50 pm
depends on the dizzy type- you get electronic ones with mechanical advance, and others without.
Ae92typeX
Postby crispy'86 » Mon Mar 27, 2006 6:51 pm
To answer your question Joe, yes the electronic distributors from the same era as 4age blue top, 4k, steu all have mechanical advance by way of counterweights/ springs in the bottom. I just looked at several and all are the same.
As for the igniters in the dizzy (of course they are reasonably the same) they are specific to dizzy in some ways with a few models. What you would need to look for is the specs for the ignitor and that they are same values as what ap[plication you use them for. All 4age early types have different pins for the igniter and wires too so as long as you have the diagram for what wire has power/ pulse from dizzy/ etc you should be alright.
The main thing to remember is are the values the same. Voltage to power up igniter is 5v compared to 3v for example. Hope i haven't confused you too much with this one
crispy'86
Postby Virtual Genocide » Mon Mar 27, 2006 7:18 pm
I hope your not using an electronic dizzy on a K engine :/
You can sum up the entire dream world of the motoring enthusiast in four words: "dont fence me in"
My Profile <----- check it out!
Virtual Genocide
Postby z|gen » Mon Mar 27, 2006 7:26 pm
Virtual Genocide wrote:I hope your not using an electronic dizzy on a K engine :/
whys that?
some K series engines come with them from factory..
AE91 SUPERCHARGED COROLLA
z|gen
Postby fangsport » Mon Mar 27, 2006 8:28 pm
i will if i can find an ignitor that will work on it. it didn't have one, but i do have a few 2tg/3teu igniters.
why, wouldn't you use one??
fangsport
Postby fangsport » Mon Mar 27, 2006 8:35 pm
crispy'86 wrote: To answer your question Joe, yes the electronic distributors from the same era as 4age blue top, 4k, steu all have mechanical advance by way of counterweights/ springs in the bottom. I just looked at several and all are the same.
cheers, i thought they would have, but it pays to check before molesting it . the motor in the engine bay is on loan, but i will have a play with it to get as much gains legal for C grade, then give it back. :twisted:
crispy'86 wrote: All 4age early types have different pins for the igniter and wires too so as long as you have the diagram for what wire has power/ pulse from dizzy/ etc you should be alright.
more than like use a T series as the plugs appear to be the same, but if it is only a voltage issue, then it shouldn't be a biggie to reduce it somehow. not overly confused by electronics, just don't like to fry things unecessarily when experimentng. :wink:
fangsport
Postby crispy'86 » Tue Mar 28, 2006 1:41 pm
That last comment is very true. I'm not one to overly like frying elec. components and let the smoke out of them..
Doing my bit to help out.
crispy'86
Postby Virtual Genocide » Tue Mar 28, 2006 7:09 pm
Just my opinion, they're an old design and not very reliable. Points will give you just as good results aslong as you know what your doing with the advance curve.
Your not going to get
if you use the points dizzy.
Be carefull with 4k electronic dizzy's some have the pulse generator inside the dizzy with an external ignitor, others have the ignitor as well as the pulse generator inside the distributer, make sure you use the correct coil.
Virtual Genocide
Postby drftnmaz » Thu Mar 30, 2006 5:17 pm
yea i take it you have a 4k dissy because every 5k elec dissy i've seen has a internal ingintor.. its only the 4k ones i've seen that dont.
why are you locking the mech advance?
drftnmaz
Postby fangsport » Thu Mar 30, 2006 10:49 pm
drftnmaz wrote:why are you locking the mech advance?
can qoute the exact term, but, when you lock the mechanical advance you can run more fixed?static? advance. whilst it does make the engine a bitch to turn over and start, it does seem to improve the power across the rev range.
i'm sure someone can elaborate further with the proper terminology and reasoning.
fangsport
Postby matt dunn » Thu Mar 30, 2006 10:53 pm
I think you will be the only one with some form of reasoning for that?
If you set up the weights and spring right you can control the advance and there is no need to lock it???
Postby fangsport » Thu Mar 30, 2006 10:59 pm
matt dunn wrote: I think you will be the only one with some form of reasoning for that?
a certain local engine builder locked up the dizzy on a certain black escort i built and it certainly hauls (when it actually enters :lol: ), and is known to do it to a few dizzy's.
fangsport
Postby suberimakuri » Thu Mar 30, 2006 11:38 pm
thats stupid to lock the dizzy on na motor.
there's no way you can run full advance at low rpm without running stupidly rich.
there are different types of ignitors....
basically for jdm k, t, r motors.... the signal from dizzy pickups goes to the ignitor (actually called a module as dumb), it controls dwell and does not do any spark/advancing.
the distributor just has vr sensor pickups and still magnetic weights to give advance... even vacuum advance (sometimes dual diaFRAM sp?)
suberimakuri
Postby drftnmaz » Tue Apr 04, 2006 12:44 pm
i had a locked dissy in my first 4k turbo and wen i changed back to a normal one it was way better. k series seem to love advance.
its only a guess but i'd imange you'd have to have massive comp ratio to run such a high static advance to compensate for locking it??
drftnmaz
Postby StuartM » Tue Apr 04, 2006 3:01 pm
if the engine is fuel injected aswell as having magnetic points the vr sensor is sometimes connected to the ecu, which controls advance.
i have seen this in 1S, 3S-GE, 3S-FE, 4A-GE, but some 16v 4A-GEs did and some diddnt have ecu controlled advance.
StuartM
Postby suberimakuri » Tue Apr 04, 2006 3:29 pm
good summary, but... all 4age's have ecu controlled advance. That's how the ecu knows the rpm. You can fit a 4k dizzy though with a spacer (if using carbs, fuel only standalone, etc), but I don't see the point.
it's only the early motors like 4keu, 2tgeu, 3teu, 18rgeu that had fuel injection and separate elec ign with weights.
suberimakuri
