Probably a little pessimistic. What's your engine worth to you? Pay for a good quality one, and expect to part with a few dollars. Cheap pumps often can't produce enough pressure to do the best job. They work yes. But not as effective as a decent pump which can produce high pressure which with the right misting head produces a really fine mist. And the finer the mist the better the system should work.sergei wrote:on the topic, does any one knows of cheap water pumps suited for this purpose?
http://www.jumbocoffee.com.au/accessories/motors.html. Check out the ulka pump as an alternative. The pump itself is AUD$95+gst and it's a similar type to the aquamist pump. Although I haven't checked out all the details on the aquamist...sergei wrote:it is very expensive, when it will get here it will be over $1000, for system wich marginally removes posibility of detonation, too much... If I could get hands on the pump I can build a controller wich will control the solenoids in similar way are injectors controlled...
Akane wrote:The pump has a MTBF and if it dies while boosting, it takes the engine with it to the graveyard.
GT4 20 wrote:[Don't bag something that you personally don't like. And I'm sure that the electical drain on the alternator will easily rob you of at least 10kW![]()
Gary
