4agze flywheels
4agze flywheels
Postby 4agtepwr » Fri Mar 24, 2006 1:17 pm
Wats the difference size wise between a 4agze flywheel and a Blacktop flywheel?
Current ride: Sweeeeet Hiace. 3L power!!!!
Project: AW11 4agte, 410kw 555hp on 26psi
11.1 @ 125.5mph with more to come, As seen in Aug 2011 Performance Car, haha
viewtopic.php?t=61383
Huge thanks to Phil from NZEFI, Al and Brendan from Caraid and Hamish from Sheifield Cresent Auto
4agtepwr
Postby sergei » Fri Mar 24, 2006 2:37 pm
These two are very different, you cannot use pressure plate of 20v on GZE or viceversa.
yup
Postby ezy10s » Fri Mar 24, 2006 3:32 pm
the clutch plate diamters are differnt also- the 20v being 212mm while the ze items vary from about 220mm up to 230mm
Member #244
ezy10s
Postby Mr Revhead » Fri Mar 24, 2006 10:48 pm
put it this way:
the only things the same are the bolt pattern to the flywheel
