Exhaust manifold torque setting?
Postby Wildcard » Sat Mar 25, 2006 1:40 am
I'm installing another stud in my turbo manifold tomorrow so I will need to re-torque all the nuts correctly - can someone tell me the torque setting for doing up exhaust manifold nuts on a 3SGTE?
Thanks
Wildcard
Toyspeed Founder
Postby sergei » Sat Mar 25, 2006 1:49 am
From US ST185 manual: 52NM
Postby Akane » Sat Mar 25, 2006 3:42 am
make sure the stud is all the way in first, and re-torque after a few heat cycles.
Best to lower the torque setting by a tiny bit.
First hand experience with Aluminium heads..........
Postby CozmoNz » Sat Mar 25, 2006 7:01 am
sergei wrote:From US ST185 manual: 52NM
tats like 32 ft init?
Rayne For President!
CozmoNz
Postby sergei » Sat Mar 25, 2006 11:29 am
38 ft lb
Re: Exhaust manifold torque setting?
Postby Crucible » Sat Mar 25, 2006 2:59 pm
Wildcard wrote:I'm installing another stud in my turbo manifold tomorrow so I will need to re-torque all the nuts correctly - can someone tell me the torque setting for doing up exhaust manifold nuts on a 3SGTE?
Thanks
just retension them again after it has cooled to prevent gasket failure. Youll find they will come up quite a bit...
tnt
Crucible
Real Life Mechanic
Postby KinLoud » Sat Mar 25, 2006 9:30 pm
When you put the new stud in thread it in by hand as much as you can before using a tool... it can be easy to crossthread stud bolts into an alumnium head... then you would need a helicoil.
Ken
Hamilton
021 408 863
Postby Akane » Sun Mar 26, 2006 6:44 am
Anymore people out there want to repeat what I've posted?
Postby MrOizo » Sun Mar 26, 2006 11:25 am
Akane wrote:Anymore people out there want to repeat what I've posted?
I will!!!
MrOizo
Toyspeed Legend
Postby fivebob » Sun Mar 26, 2006 12:26 pm
No but I’d like to correct your misinformed reply :twisted:
Akane wrote:Best to lower the torque setting by a tiny bit.
Why on earth would you want to lower the manufacturers recommendations, that's just stupid, however I would suggest reading Kinloud's excellent advice.
KinLoud wrote:it can be easy to crossthread stud bolts into an alumnium head... then you would need a helicoil.
I guess your "experience" with Aluminium heads is that it's easy to cross thread the stud if you don't know what you are doing, then you just (wrongly) blame the manufacturers (correct) torque settings for your ineptitude :roll:
Postby Wildcard » Sun Mar 26, 2006 12:41 pm
Thanks for the various advice, stud went in like a charm and all torqued up perfectly 8)
Wildcard
Toyspeed Founder
Postby Akane » Sun Mar 26, 2006 1:17 pm
Funny how you don't mention anything about the first 2 things I said fivebob, you should just chime in like the others and repeat what I say over and over again.
Or was that too easy to miss, and you have to TRY to pick on something that is more logical. Please refer to the following:
Well, maybe you would love to stick to the manufacturer's specs. I'm sure it's better to risk stripping a thread in the alloy head (let it be aging on the head, or dodgey torque wrench that you've bought, or maybe fivebob has rain down his unlucky enchantments on you), than found out you have an exhaust leak and retorque with a higher setting later on.
Yes fivebob, you're "teh win".
Users browsing this forum: No registered users and 42 guests
