13 RPM Signal
13 RPM Signal
Postby Zyros » Mon Mar 27, 2006 10:36 pm
13 RPM Signal
Diagnosis
* No "NE" signal to ECU when engine speed is about 1,000 RPM.
Trouble Area
* Distributor, or CPS, circuit
* Distributor or CPS
* ECU
Thats the error i get, and it misfires when warm and the check engine light flashes every time it misses.
Now, i have done.
Done the loom to the Distributor and the ecu, New cap, Distrubutor leads, New rotor inside the distributor itself and the ECU..
Aslong as alot of other stuff.
Anyone have any idea's!!
Zyros
Postby Zyros » Mon Mar 27, 2006 11:46 pm
Bump before im off 2 sleep :)
Zyros
Postby Caveman » Mon Mar 27, 2006 11:49 pm
Have you done the crank angle sensor yet?
Caveman
Postby Zyros » Mon Mar 27, 2006 11:52 pm
1998 wrote:Have you done the crank angle sensor yet?
I bought that up and they said that's the electronics inside the distributor (or something similar)
So it would of being changed if the distirubtor has being changed, what it has?
Zyros
Postby slighty_sykotic » Tue Mar 28, 2006 3:12 pm
Have you accutly changed the WHOLE dizzy?
--Sykotic
slighty_sykotic
Postby Zyros » Tue Mar 28, 2006 4:44 pm
slighty_sykotic wrote:Have you accutly changed the WHOLE dizzy?
--Sykotic
Yup, THE ENTIRE DISTRIBUTOR has being replaced..
Where is the earth for the distributor? Could it be that?.. where is it? lol
Zyros
Postby sergei » Tue Mar 28, 2006 4:55 pm
Technically G- is "ground" ground wire for distributor, BUT DO NOT CONNECT IT TO GROUND (as it grounds through a circuit inside ecu, probably through a differential amplifier due to low voltage nature of signal). Check if shielding on the loom going from distributor is intact and connected to ground.
Postby matt dunn » Tue Mar 28, 2006 7:21 pm
sergei wrote:Check if shielding on the loom going from distributor is intact and connected to ground.
there's that sheilding i was trying to explain to you.
Matt
