why isnt my central locking working
Postby GTCRSHR » Wed Mar 29, 2006 12:14 pm
AE101 fxgt,
the passenger side isnt working,
where do i start :?: or what do i need to replace
Nothing to see here ...
GTCRSHR
Postby Mr.Phreak » Wed Mar 29, 2006 12:16 pm
Because you forgot to plug it back in when you put your trims back on?? :D
Mr.Phreak
Postby GTCRSHR » Wed Mar 29, 2006 12:18 pm
Mr.Phreak wrote:Because you forgot to plug it back in when you put your trims back on?? :D
:oops: :oops: 8O 8O 8O
no it wasnt working before i took the door cards off
well not properly it TRIES to close it like say 2mm and then thats it will close the drivers side fine
GTCRSHR
Postby Mr.Phreak » Wed Mar 29, 2006 12:22 pm
Actuators possibly died
Mr.Phreak
Postby sergei » Wed Mar 29, 2006 12:24 pm
Check how easy is to lock it manually, then listen when you activate the central locking if you could hear the motor trying to lock/unlock that door, it could be electrical (power not getting to motor) or mechanical (jammed motor), pull apart door trim locate plug for that motor (should be in bottom of the door corner) measure the voltage between the pins on the plug (with motor connected, than with it disconnected), if you are getting voltage with motor connected it means that motor is jammed, either replace it or repair the jam, if you are not getting the voltage on the plug with motor disconnected, remember the colours of the wires and trace back to Door Control Unit and see if the wires intact (test resistance), the door control unit is located behind pasanger glove box (orange or black box, it says on the side of it "Door Control Unit", you could hear relays clicking inside of it when central locking activated).
Postby GTCRSHR » Wed Mar 29, 2006 12:24 pm
is that the black thing ? about 4-6 inches long shaped like the end of a gun sortof
GTCRSHR
Postby GTCRSHR » Wed Mar 29, 2006 12:26 pm
sergei wrote:Check how easy is to lock it manually, then listen when you activate the central locking if you could hear the motor trying to lock/unlock that door, it could be electrical (power not getting to motor) or mechanical (jammed motor), pull apart door trim locate plug for that motor (should be in bottom of the door corner) measure the voltage between the pins on the plug (with motor connected, than with it disconnected), if you are getting voltage with motor connected it means that motor is jammed, either replace it or repair the jam, if you are not getting the voltage on the plug with motor disconnected, remember the colours of the wires and trace back to Door Control Unit and see if the wires intact (test resistance), the door control unit is located behind pasanger glove box (orange or black box, it says on the side of it "Door Control Unit", you could hear relays clicking inside of it when central locking activated).
cheers for that will have a look at it tonight
it tries to close the lock, moves it about 2mm or so but it just wont move it enough to lock it ?
sound electrical
GTCRSHR
Postby sergei » Wed Mar 29, 2006 12:29 pm
well if it tries to move, either pushrods are bend/obstructed/rusted or the acutator needs to be serviced or replaced.
Postby GTCRSHR » Wed Mar 29, 2006 12:31 pm
is the actuator easy to get too ?
GTCRSHR
Postby sergei » Wed Mar 29, 2006 12:39 pm
yep, you will have to remove door trim, and it should be located on the bottom in the corner of the door.
Postby GTCRSHR » Wed Mar 29, 2006 12:40 pm
Thanks for that i will have a look tonight
GTCRSHR
Postby GTCRSHR » Thu Mar 30, 2006 2:45 pm
well after having a look last night,
i cant for the life of me figure out how im suppose to get the actuator out
it looks to me like i need to service it, it is working but just not properly
rods are fine no damage to them and the actuator clicks over but just not enough to open and close the lock
GTCRSHR
Postby 85AW20v » Thu Mar 30, 2006 9:36 pm
CRC....
See ya
Simon
85 MR2 20v
85AW20v
Postby Mr.Phreak » Thu Mar 30, 2006 9:40 pm
It's probably stripped the gears inside, just replace it....they're not exactly expensive
And c'mon Gate, thought you know if you can't get something out, you just need a bigger hammer :wink:
Mr.Phreak
Postby samlloyd » Thu Mar 30, 2006 10:43 pm
Is your interior light working?
samlloyd
Postby GTCRSHR » Fri Mar 31, 2006 12:06 pm
how do i get the actuator out ? does any one have a diagram please
i dont have the interior light plugged in ?
GTCRSHR
Postby MrOizo » Fri Mar 31, 2006 12:53 pm
these actuators are bitchnuts of things to get out!
there is like 2 bolts holding it in and a loom going to it..
(oh and the arm which goes to tthe locking mechanism)
with a bit of sussing out you'll be able to get it out..
might wanna go to pick a part and practice on them ones before doing your own ;)
MrOizo
Toyspeed Legend
Users browsing this forum: Google [Bot] and 17 guests
