blacktop
blacktop
Postby widebodyhachi » Sun Apr 02, 2006 10:53 pm
Im planning a build for a blacktop 20v GT Corrolla,
Im going to have 304degre factory lift TODA cams and adjsutable cam gears, TRD valve springs, adjustable ECU most liley freedom, wanting extractors made to match cam profiles but I cant find any infomation on the cams TODA wont give it to me unless I buy cams, where can I get infomation on cams of these specs
widebodyhachi
Postby Al » Sun Apr 02, 2006 11:00 pm
Why is that an issue? Buy the cams since you intend to anyway and get the information you need. Or do you not have any money?
Al
Postby widebodyhachi » Sun Apr 02, 2006 11:49 pm
im doing reaserch I want to drop gearbox and engine already done straight into car so I can just focus on final set-up rather then have to keep adjusting everything as I add the next bit
widebodyhachi
