Possesed Speedo
Possesed Speedo
Postby B_giB » Tue Apr 04, 2006 9:07 pm
My speedo on my AE101 levin GT Apex is possesed, jumps all over the place, when i pull out to pass someone on the motor-way it goes right back to 0!!!
kinda wierd, thought maybe cable but i couldnt find one :?
all input appreciated.
all other guages seem to be workin the norm
Current: SXE10 Altezza
Previous:AE86 Trueno Notch Back: Gone but not forgotten :cry: :(
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby Silent Knight » Tue Apr 04, 2006 9:20 pm
These are cable driven ay?
Check where it goes into your G/B to see whether it's still sitting tight in there and is properly lined up.
I think when you take it out there's a little clip thingee in there not sure what to call it which might be causing the issue....
Silent Knight
Postby trueno_20v » Tue Apr 04, 2006 9:32 pm
Silent Knight wrote:These are cable driven ay?
No they are electronic i think, check the plug on the G/B around the back by the starter, im pretty sure thats the speedo one..i might be wrong though lol
ADMIN EDIT: signature too large
trueno_20v
Postby CAMB01 » Tue Apr 04, 2006 11:02 pm
AE101 20v's are electronic speedo
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby gepsk8 » Wed Apr 05, 2006 12:32 am
the speedo is electric on top of the diff, 3wire plug real bitch to unplug.
go to p-a-p get 1 out of any toyota thats the same (e.g AE101 or coronas, anything of the same sort of years) fit it and it should be fixed.
i can get 1 if u can't find 1.
gepsk8
Postby FLAWLES » Wed Apr 05, 2006 2:36 pm
hahahahahaha mine to does this but only on a hot day
there are indeed run off a speed sensor that is pooked in to the back of the g/box
i wouldnt reqomend just going to a wrecker and slaping any sensor in as you may find that they might have diff input/out puts
just match up the numbers on the back of your existing sensor to the second hand one.
or just go buy new :P
but hay who needs a speedo 5th gear 3tho rpm is a 100km
forget what 60km is
FLAWLES
Postby B_giB » Wed Apr 05, 2006 7:48 pm
thanks guys and gals, will check tomorow if i have time :)
B_giB
Users browsing this forum: Google [Bot] and 3 guests
