pulley kit
pulley kit
Postby bluemaumau » Sat Apr 08, 2006 7:59 pm
a friend of mines dads a engineer and has all the tools 8)
im thinking of getting him to make my pulley smaller for more boost(AE92 4agze)
1. how big must the pulley be for 12-14psi?
2. if i get the pulley made smaller do i need a smaller belt? or do i just need to move the tensioner?
3. is there anything to watch out for, ive heard something about "harmonic balancing" 8O
so basically where is evil_si? :P
no, but if you have any suggestions/ comments post away
Postby CAMB01 » Sat Apr 08, 2006 8:18 pm
You want to make the pulley larger not smaller. Larger pulley means more boost :)
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby evil_si » Sat Apr 08, 2006 8:28 pm
you can do it 2 ways,
direct drive and make a smaller drive pulley on the actual supercharger. will need a shorter belt.
make a larger crank pulley, size depends on if you want to change the waterpump pulley, will need a smaller tensioner and longer belt.
harmonically balanced is the type of pulley, not the way it is balanced.
some guys use solid alloy pulleys, i wouldnt as engines arnt cheap. they tend to fu.k engines quickly, to much loading on the crank,
evil_si
Postby trueno_20v » Sat Apr 08, 2006 8:30 pm
CAMB01 wrote:You want to make the pulley larger not smaller. Larger pulley means more boost :)
No dont you make the pulley smaller so it spins faster = more boost.
ADMIN EDIT: signature too large
trueno_20v
Postby gdsup » Sat Apr 08, 2006 8:34 pm
just buy one of evil_si's, if you are unsure of the detail save yourself the time and hassle, buy it, bolt it ,drive it - done
gdsup
Postby bluemaumau » Sat Apr 08, 2006 9:01 pm
gdsup wrote:just buy one of evil_si's, if you are unsure of the detail save yourself the time and hassle, buy it, bolt it ,drive it - done
i can get this for free, i dont have 300 hundy :roll:
hmm always thought it was smaller pulley, more boost?
what do you do evil_si?, without giving away your trade secrets?!
Postby beeker » Sat Apr 08, 2006 9:08 pm
evil_si wrote:you can do it 2 ways,
Do make different sizes ? 14psi is too big for my needs.
I have an AE86 powered by a 4agze from a AE101 (running 170hp stock), and as its used for Targa it gets allot of WOT and a general solid hiding! I would like more power, but not too much to burn that S/C out prematurely. Any recommendations for size and expected HP ?
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby evil_si » Sat Apr 08, 2006 9:26 pm
yea i can do any size.
power and the boost output depends on the condition of your engine and the supercharger.
i can do a hks size kit, will offer up to 12psi
evil_si
Postby beeker » Sat Apr 08, 2006 9:32 pm
evil_si wrote:yea i can do any size.
Is there a way to test them without removal ?
What kind of addional HP can you expect from a 12psi pulley ? Im current boosting to 8.5psi on stock
Can you still get good condition SC12's ? I'm starting to assume that all of them would be 100,000km ++ by now.
06 RS4 Avant
beeker
Postby evil_si » Sat Apr 08, 2006 9:33 pm
just remember free isnt always best. if its not done right it will cost you in the long run.
as i said earlier there is 2 ways of achieveing it.
a smaller pulley can only be on the receiving end,
i dont play with the supercharger pulley unless specifically requested, its more hassle than what its worth. direct drive is a pita.
larger pulley drives the small pulley faster.
if you have a lego set with the electric motors try it. a big drive motor will spin the wheel faster, a small drive motor will spin a wheel slower.
if you dont under stand simple drive theory's its probably best you dont change it.
evil_si
Postby bluemaumau » Sat Apr 08, 2006 9:38 pm
um so how do you make the standard item bigger?
Postby FrEsH » Sat Apr 08, 2006 9:40 pm
you replace it
FrEsH
Postby evil_si » Sat Apr 08, 2006 9:40 pm
beeker wrote:Is there a way to test them without removal ?
not really, testing them involves checking the rotor clearances, the seals and bearings.
its been a while since ive had one apart, i cant remeber if they have straight or helical gears, i would imagine helical if so clearances can be changed by adding or removing shims.
to be honest i have never dynoed them so do not know the exact power increase between the pulley sizes.
i have seen a comparison on another website between the pulley sizes and boost levels, i will try and dig it out.
evil_si
Postby KinLoud » Sat Apr 08, 2006 9:56 pm
Early (AFM) AE92 4agze engines have a bigger pulley on the supercharger itself than the later ones.
When the MAP 4agze engines came out they had a smaller s/c pulley - so the super charger spins a bit faster than the earlier ones so they have a bit more boost.
Are you running AFM or MAP?
If MAP, don't change the s/c pulley but think about a bigger crank pulley.
However - spin the s/c faster and you get a bit more boost but lots more heat (this is because the roots type s/c isn't efficient at higher boost levels)
Spin the toyota s/c too fast and the teflon coating melts/wears off and you will lose boost!
Ken
Hamilton
021 408 863
Postby beeker » Sun Apr 09, 2006 12:34 am
KinLoud wrote:Early (AFM) AE92 4agze engines have a bigger pulley on the supercharger itself than the later ones.
Ken
Hamilton
021 408 863
I believe the AE101 is map, Stock 170hp. So the question is, what is the recommended sustainable boost (and thus pulley size, crank pulley if thats whats recommended) for a high WOT application?
I've made the assumption that 14psi is too high, and that maybe a 10 or 12psi would be ok. Pure guess work. I would like to know what additional HP a 10 or 12psi pulley would give me though.
06 RS4 Avant
beeker
Postby bluemaumau » Sun Apr 09, 2006 12:56 pm
ive got the afm, so you reckon fitting a ae101 s/c pulley is the way to go?
Postby Crucible » Sun Apr 09, 2006 8:13 pm
beeker wrote:I've made the assumption that 14psi is too high, and that maybe a 10 or 12psi would be ok. Pure guess work. I would like to know what additional HP a 10 or 12psi pulley would give me though.
Ive bought two pulleys off Evil_si, a 165mm and a 175mm. I fitted the 165 kit to my Dads 101 levin and the other to my 101 Trueno. My old mans Levin produced 11-12psi and I was getting 14psi but Dads seemed to pull alot better than my car which had the bigger pulley. Everything else on both cars were identical,exhaust,Coolers etc. The only thing I could put it down to was maybe the charger was starting to become inefficient and was starting to pump hot air above 12psi. Now I know this dont mean jack unless I had both cars on a Dyno but both me and my Dad could really feel the differance between the two, it was quite noticeable. However if I had gone to the effort to fit good water to air cooler Id say it would of been alot better :lol:
Crucible
Real Life Mechanic
Postby aesc » Sun Apr 09, 2006 8:57 pm
OK, just a note that the 175mm pulley in most cases wont give 14psi, your prob gonna get 13psi max.
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Crucible » Sun Apr 09, 2006 10:01 pm
aesc wrote:OK, just a note that the 175mm pulley in most cases wont give 14psi, your prob gonna get 13psi max.
I got 14psi on a cold night eazy peazy (Autometer Gauge), I know of two other 101 gtzs with 14 and over all with good brand boost gauges, maybe its 14psi max with a 175mm pulley? :lol:
Crucible
Real Life Mechanic
Postby CAMB01 » Sun Apr 09, 2006 10:31 pm
Im getting 13 - 15psi on my GZE with 175mm pulley
I do notice that it doesnt like high revs cause of the heat it generates.
A more efficient cooler should fix that problem.
Plus i have a MAP GZE which has the annoying 5500rpm drop.
CAMB01
