he retarded it slightly and this would make the car go a little better?
StuartM wrote:depending on what RON fuel you use, you will have more driveability and maybe power at low rpm but.. because the base timing has been retarded you will have less total advance at high rpm.
I take it you have a fuel injected & computer spark controlled engine but what engine exactly?
set the timing to the manufacturers specifications because with the base timing off the computer will be unable to accurately control dwell and spark.
slighty_sykotic wrote:And they you go drive your 16v/20v on 95 fuel and kill it or it's preformance. Stupid idea... Would be good to set it to manufactors setting IF you ran it on manufactor's required fuel, which you can't in NZ. So therefore you retard the timing to make up for it.
StuartM wrote:
perhaps you dont realise that spark control is based upon an accurately timed signal received from a variable reluctor sensor inside the distributor. this signal is expected to be at a certain cam angle and if you go screwing with it the ignition coil dwell and computer spark control will be out-of-sync, you can see this with a timing light easily as the timing jumping all over the place at idle. and BTW there are knock-retarding (not ignition retarding) chemicals in most fuels so unless this is a 200+ HP engine he won't be damaging it.
StuartM wrote:dwell is the minimum amount of time the coil will be charged for, dwell time and ignition advance is entirely controlled by the ECU. therefore for the ECU to be operating correctly the timing must be correct. but im not trying to say your wrong here, you get more economy from retarding your timing, but for power you need a certain amount of advance. your GZE is blown so you really need retarded timing.
RedMist wrote:I'm afraid Stuart that the ECU doesnt calculate dwell. The igntor does.
And base timing can be altered to alter timing much like an old mechanical advance dizzy. The ECU does nothing but advance the timing additional to the hall sensor base timing. So altering the base timing alters the total advance. It gets a little more complex with squential injection driven off the same CAS (cam or crank angle sensor).. but not much.
RedMist wrote:Oh, and the reason you see timing on a timing light jumping around is probably because you havent jumpered the ECU and its hunting between two MAP zones. Either that or your engine doesnt run smoothly (much as mine does with big cams) and the cam belt is flexing or shaking. Or option number 3, you're running one of the early Link LEM's 4 or below with poor code.
