Mk3 Supra
Mk3 Supra
Postby Brevin » Wed Apr 12, 2006 11:44 am
So Supra's back up and running, and running sweet. Only problem is, i want more power :twisted:
So, what should i do? Keep the 1G-GTE? If so what mod's should i do to it?
I was thinking about a 1JZ, i've seen a few around... but would it really be worth it? What would i need for the conversion? Could i still use the same xmember?
If i decide to stick with the 1G, would i be able to extract a sufficent ( :twisted: ) amount of power out it to keep my cravings at bay?
Nick.
Despicable angles
Brevin
Postby HELBND » Wed Apr 12, 2006 11:47 am
Be different - go 2j :P
waits for hare to say 1J
HELBND
Postby Silent Knight » Wed Apr 12, 2006 11:51 am
This belongs in the Tech section and this same discussion has been covered numerious times on the board.
What you call sufficient power? <--- This will decide whether to keep the 1G or not.
If your Supra is post 89 with the round instead of square xmember then you can use the same one for a 1J conversion.
I would personally go with a 1J as it puts out a whole heap more power and torque from factory and it's easier to get more out of than a 1G would be.
In the end this all will come down to budget....so before I can continue telling the whole story again have a search in the Tech section and give more info on your Supra eg. What year was it manufactured?
Will also need to know how much power you are craving for and roughly what sort of budget you have...
Bitch my name is Hanré!!! :P
Silent Knight
Postby Brevin » Wed Apr 12, 2006 11:59 am
Mods, please shift too tech section.
Really want somewhere between 350hp - 400hp (preferably up the 400end)
Budget isn't a problem, I'm working 2 well paying jobs and have a fair amount saved up.
Car's an '87 Mk3. Pretty much stock except the exhaust, fmic and fuel pump...
Would love to, and would've already purchased and engine if i could find one of the bastards!
Despicable angles
Brevin
Postby Silent Knight » Wed Apr 12, 2006 12:06 pm
Ok well since it's an 87' you'll need a different crossmember to be able to fit a 1JZ in there...
You can get those figures from a 1G just not as easy as you would with a 1J. Hunt is well on his way to making 400hp with his 1G although I'm not sure whether it is going yet or not.
What you'll need is a good free flow exhaust, fmic, fuel pump, injectors, bigger single turbo, bov and then an ECU with a good tune. Normally it's better to go full replacement ECU like Power FC, Haltech, Microtech, Link etc but you will also be able to get the maps nicely tuned with a Piggy back the likes of the GReddy E-manage.
When possible it's always better to replace the whole unit with another one. Less to go wrong...
With that a proper dyno tune you'll have your 400hp with the 1G.
The above will not however come cheaply by a long shot....
Silent Knight
Postby MrOizo » Wed Apr 12, 2006 12:23 pm
Silent Knight wrote:Ok well since it's an 87' you'll need a different crossmember to be able to fit a 1JZ in there...
thats true if you want a bolt up solution.
another option is having mounts fabricated. there isnt that much difference between the per-facelift and facelift x-members, but enough to make the 1JZ (JZA70) mounts not line up properly.
If you can find a facelift x-member as well as the ZJA70 engine mounts then go for it. otherwise just have some one fabb some up for you which bolt up to the pre facelift setup.
Damn all this MKIII Supra talk lately is making me have withdrawls! :?
One day i'll be in another one..... one day :P
MrOizo
Toyspeed Legend
Postby HELBND » Wed Apr 12, 2006 12:25 pm
waits for hanre to say 1J
bah i got lazy with my typing :P
and i was supposed to be working :lol:
HELBND
Postby Brevin » Wed Apr 12, 2006 12:25 pm
what size injectors would i need? 500cc? 800cc? I've been looking, and would injectors made for a 1JZ, fit into my 1G?
I've got my eyes set already on a link computer from a friend of mine, so computers not a problem.
What kind of turbo would you recomend?
Despicable angles
Brevin
Postby Si » Wed Apr 12, 2006 7:59 pm
if you working two jobs.....
you can buy my jza70
10k as is where is, inc the two sets of skid rims, and dvd/mp3/tv setup.
rock on :)
Current: , '96 SubaruImpreza
Si
Postby Malcolm » Wed Apr 12, 2006 8:09 pm
my vote is to put in a 1uz and put a turbo or two onto it. Easy reliable power, plus all the torque you need for the heavy beast. Much better than spending up on a little wee torqueless 2L
Postby Silent Knight » Wed Apr 12, 2006 8:13 pm
All_Fours wrote:my vote is to put in a 1uz and put a turbo or two onto it. Easy reliable power, plus all the torque you need for the heavy beast. Much better than spending up on a little wee torqueless 2L
That is exactly what I've been planning for my next project MKIII. 8)
Silent Knight
Postby Malcolm » Wed Apr 12, 2006 8:24 pm
you mean you're actually planning to buy a mk3? I thought they were the kind of car you bought on a whim without much forethought, to later realise you were getting the worst of both worlds (all the space of a small coupe, all the weight of a 4 door)
:lol: :lol:
lightweight = best :)
Postby Silent Knight » Thu Apr 13, 2006 8:24 am
All_Fours wrote:you mean you're actually planning to buy a mk3? I thought they were the kind of car you bought on a whim without much forethought, to later realise you were getting the worst of both worlds (all the space of a small coupe, all the weight of a 4 door)
:lol: :lol:
No No No Malcolm.
You obviously do not share the great love of the MKIII here. They are one of THE most beautiful cars that Toyota has ever created. The weight problems can be sorted out and who cares how big the back seat is when you are driving... :P
Silent Knight
Postby 1loose_mr2 » Thu Apr 13, 2006 11:07 am
ive got a 1jz forsale if anyone interested
http://www.trademe.co.nz/Browse/Listing ... d=53394163
1loose_mr2
Postby blackmk3 » Fri Apr 14, 2006 10:22 am
^ i coundnt agree more!
Mk3 MA70 Supra
blackmk3
