Anyone help? 1990 rolla ee90 wagon with 4e-fte starlet turbo
Postby phillfone » Thu Apr 20, 2006 12:37 pm
Hi,
I have a ee90 corolla that I converted to a 4e-fte starlet turbo, I used origonal 2e gearbox which hasn't lasted long, it already had done 300,000 before conversion, its noisy az, and oil is leaking from the bottom.
I have been thinking of converting the wagon to four wheel drive with the running gear from a import toyota carib wagon, as far as I can tell this should bolt straight into an ee90 wagon, I will change the fuel tank to fit the driveshaft, but can the bellhousing from my origonal ee90 2e gearbox fit onto the 4wd gearbox? and what clutch would be best to use? the engine has the 2e flywheel on it.
feedback appreciated
phillfone
Postby soopachargen » Thu Apr 20, 2006 6:34 pm
is a 4efte gonna have enough torque to pull a 4wd system around??
When in doubt, down and out.
soopachargen
Postby bluemaumau » Thu Apr 20, 2006 8:20 pm
soopachargen wrote:is a 4efte gonna have enough torque to pull a 4wd system around??
yea bro what he said.
remeber that the old caribs had the engine mounted in a RWD position, so thats gonna cause some shit.
maybe just use all that carib stuff and use a RWD box(t series/ w series)
and go RWD, better gains than FWD or 4WD.
food for thought 8)
Postby fuel » Thu Apr 20, 2006 11:06 pm
Errr.. only the early to mid 80s model Caribs used the North/South engine layout dude. The AE95 (I think?) Carib uses transverse mounted East/West engine layout with A series engine.
LOUD NOISES!!!
fuel
Postby Alex B » Thu Apr 20, 2006 11:10 pm
Ae95 is correct, with a mighty 4a-f :lol:
Postby bluemaumau » Fri Apr 21, 2006 12:35 am
fuel wrote:Errr.. only the early to mid 80s model Caribs used the North/South engine layout dude. The AE95 (I think?) Carib uses transverse mounted East/West engine layout with A series engine.
my bad, i thought only the reallllly old caribs were 4wd,
owell there you go dont get a early to mid 80's carib driveline!!!! :P
Postby Alex B » Fri Apr 21, 2006 1:26 am
I wouldnt eh, the boxes are crap.
Postby phillfone » Fri Apr 21, 2006 4:48 pm
pyro_sniper2002 wrote:I wouldnt eh, the boxes are crap.
Sweet as maybe I stick to frontwheel, anyone know what the strongest box clutch combo would be, its getting some new toys soon eg. tdo4, external waste gate, and upgraded fueling.
Cheers ya'll
phillfone
Postby Stu- » Fri Apr 21, 2006 5:05 pm
You need a C52 from a Ep82 or EP91 Starlet.
Project Thread
Stu-
Postby CozmoNz » Fri Apr 21, 2006 5:52 pm
we forgetting an EE90 is fwd only and a driveshaft wont fit?
Rayne For President!
CozmoNz
Postby phillfone » Fri Apr 21, 2006 7:26 pm
CozmoNz wrote:we forgetting an EE90 is fwd only and a driveshaft wont fit?
Yeah drive shaft will fit for 4wd model, cos has tunnel there, just needs fuel tank from 4wd model to accomodate driveshaft
phillfone
Postby CozmoNz » Fri Apr 21, 2006 7:34 pm
oh ok, meh, do it then.....
CozmoNz
Postby tatsumaki » Fri Apr 21, 2006 9:47 pm
You could get a C50F box and transfer case off a EP85 or EP95. This would allow you to keep the 4E-FTE engine yet setup a 4WD transmission.
PB.
tatsumaki
Postby quinny » Sun Apr 23, 2006 12:32 pm
i have 2 complete 4wd drive trains ex carib if any use to anyone and the 4wd gas tank as well
currently beating - AE101 Sedan, blacktop/6spd, tein coilovers, braided lines, cup holder, and every other bloody thing possible.
quinny
